My peells micro 28" v hull
  • kennyrach
    • 102
    Hi all .Here you see me building my first Peells boat and i have the hull send out to get laser cut.I would cut my own but I fell off roof in 2003 and have 3 main op and two 3" rod and an neurostimulator install .so I can not use power tool anymore .So first let me say Pete know how to build boat and they are 100% super i have build many boat before .but this is the first time i can build a boat with my 7 year old son and we are enjoying it .So hat off to you Pete .Now here what i did already .I lay out all mark on work bench and made a line down middle then i 5min epoxy the 1/8 stringers which was steamed to bend easily .take So here some picture of it
    http://kennyrachtrains.com/
  • kennyrach
    • 102
    boat picture
    [ATTACH]13441[/ATTACH]
    [ATTACH]13442[/ATTACH]
    [ATTACH]13443[/ATTACH]
    [ATTACH]13444[/ATTACH]
    [ATTACH]13445[/ATTACH]
    • kennyrach
      • 102
      some other boat
      here are some other boat i am working on .and my shop and here you can see my 7 year old son workbench and as you can see i have 12v sander and 12v ROTARY TOOL PICT0017.JPG
      • j.m.
        • 847
        You sure got your work cut out for you sheeting all those hulls!
        • kennyrach
          • 102
          Yep i do he he these are for winter to do
          • Flying Scotsman
            Fast Electric Adict!
            • 5195
            Great to see people building hulls. The Dauntless in your pictures took me 3 years of on and off building to complete. Also, it is fantastic that you have a young helper.
            Douggie
            • kennyrach
              • 102
              Yep he make my day and i just started The Dauntless 3 week ago and i just did an 48' Dumas pt 109 with a OS 45 engine
              • kennyrach
                • 102
                Hi all .Ok here what i did today i sand the hull and put the side on here some picture of today work .
                [ATTACH]13490[/ATTACH]
                [ATTACH]13491[/ATTACH]
                [ATTACH]13492[/ATTACH]
                [ATTACH]13493[/ATTACH]
                [ATTACH]13494[/ATTACH]
                • kennyrach
                  • 102
                  ok i i thing i am going to jet drive this boat with a Graupner Mini Jet (2349)2349_lrg.jpg
                  • j.m.
                    • 847
                    Do two if you go with the mini, it's not nearly enough power.
                    And still, I think you'll be wanting more speed. A 4s setup with a feigao 9xl or 8xl sounds much better....
                    • peells
                      • 739
                      Bob,
                      Looks great you have been very busy in your shop keep up the great work!! I am running a Feigo 9xl with water cooling and a x438 prop with 6s and I am going to change to 2-4s packs in parallel and prop up a bit,
                      I have a new hull which will be better for dual jet drives than the Nitro Hunter, I call it the Nitro Eliminator, The front looks similar to the Nitro hunter but I widened it out to 9" and squeezed the thickness down in the back (narrowed the V) flattening out the v in the back considerably.
                      Peter Eells; Fun, and Helping others To Have Fun!!!
                      http://rcboatsbypetere.blogspot.com/
                      RC.Boats.by.Pete@gmail.com
                      • kennyrach
                        • 102
                        Hi Pete .Sound good to me any picture of it And yes been working hard just finish 1/8 atlas van line hull and started to sheet your hull .pic coming soon .also i am looking for not so fast set up for my son Nitro Hunter it all balsa wood made
                        • kennyrach
                          • 102
                          Hi all .i worked on boat today and sheet it and add rail inside to hold down cover and add support to it .So here more picture on what i done .so now i need to thing hard to see what motor to you in this one ? 9xl or 8xl .so now i am going to fiberglass now with 2oz mat .picture are on next post thank all
                          • kennyrach
                            • 102
                            [ATTACH]13585[/ATTACH]
                            [ATTACH]13586[/ATTACH]
                            [ATTACH]13587[/ATTACH]
                            [ATTACH]13588[/ATTACH]
                            [ATTACH]13589[/ATTACH]
                            • kennyrach
                              • 102
                              Hi all Here what i did today .Hope you guy/lady like it so far
                              [ATTACH]13643[/ATTACH]
                              [ATTACH]13644[/ATTACH]
                              [ATTACH]13645[/ATTACH]
                              [ATTACH]13646[/ATTACH]
                              [ATTACH]13647[/ATTACH]
