H&m intruder s
    • 9481
    Originally posted by bigpapa View Post
    just redid mine with a facelift and first run stats check it out here
    http://forums.offshoreelectrics.com/...ead.php?t=8826
    I'm still blown away on how fast that is with the UL-1 combo!
    and mine still sets at 32mph with the sv27 combo..
    • bigpapa
      • Apr 2009
      • 2531
      tks, gonna try to tap the 60 mark saturday if weather holds off added 3 caps to esc and raised strut alittle sharpned prop alittle moore so we will see tks .......... moved cog alittle more foreward also
      THUNDER TIGER OUTLAW,THUNDER TIGER BANDIT
      CARBON FIBER MINICAT HYDRO,MINICAT HYDRO,PROBOAT MISS GEICO,SKUNKWORKS 32" CAT TWIN, H@M VIPER TURBINE ---JEFF WOHLT WIRE DRIVES
        I'm still blown away on how fast that is with the UL-1 combo.....and mine still sets at 32mph with the sv27 combo..
        Don't get too upset, in the video that Intruder is running an Ammo 2300 motor on 4S with a big prop, not a UL-1 motor. Still very fast, I'll be interested in the speed once it can stay on the water like a real boat.
        Your MM should do better than 32 mph with the SV motor. What prop and cells are you running? Strut depth and angle? CG placement? That hull 'should' be capable of near 40 with that setup...
          • 9481
          Ammo 2300, I thught it was the stock motor.. ok now I feel a bit better
          I am running 5200mah 30c packs, a S220 prop (43.7mm), strut is set to 0 ( better speed and performance), and COG is 25-30%
          I had the strut at 3/16th then moved it to 1/8th then to 0"
          I do have a second motor that I am going to try and see if I have a motor issue..
            #35
            Mine runs plenty fast with a BJ motor with the bottom of the strut 3/16" above the sponson bottoms and angled up 2 degrees at the prop end. Do this on a flat table, not "by eye".
            You may try an m445 or an x642 prop, but I'm not certain about the SV motor. Another club member has a UL-1 motor in his MM for LSO racing and has GPSd it at slightly over 40 mph - although he is probably closer to 36-38 most of the time. Water conditions can make a big difference as can hull trim. But IMO 32 mph is too slow....
              • 9481
              #36
              Yep 32mph is to slow!
              • DINO7
                • Jan 2009
                • 165
                #37
                finished boat....
                soon some test results..
                H&M Intruder S twin Leopard 36/74/3270 @ 3S-HIFEI 200A
                MHZ mystic 114-TP4050 5D-HIFEI 240A hv ESC- @ 2 x 5S
                BANDIT S"love boat" LEHNER POWERED.. RCFASTBOATS.GR MINI COOPER CAT
                • DINO7
                  • Jan 2009
                  • 165
                  #38
                  • bigpapa
                    • Apr 2009
                    • 2531
                    #39
                    one fine little lady there congrats !!!!!!!!!!!!
                    • DISAR
                      • Aug 2007
                      • 1137
                      #40
                      Beautiful and for first boat excellent job!
                      http://www.rcfastboats.com/
                        • 9481
                        #41
                        Sexy!
                        • Fastang347
                          • Apr 2009
                          • 100
                          #42
                          nice
                          • Jesse J
                            scale FE enthusiast
                            • 7818
                            #43
                            Great job, man these boats are awesome. I just love their looks and you dun did a fine job dressin her up!
                            "Look good doin' it"
                            See the fleet
                            • DINO7
                              • Jan 2009
                              • 165
                              #44
                              thanks.my seaking 120A is probably dead.no power to the motor but bec works.i dont know....so i ordered a etti 150 non bec.maybe tommorow i will have it here.so stay tuned for testing with various props at 4S and 5S.with max speed ,watts,esc temp ,motor temp and max amper
                              • Fastang347
                                • Apr 2009
                                • 100
                                #45
                                when you ready to sell it lmk
