1. I use a dremel tool and soft metal (copper) brush to clean off the mold slag. Wear some kind of eye protection and do not inhale the prop filings/dust.
2. Use a dremel tool stone to remove the mold marks.
3. Use a flat file to sharpen the the leading edge of the prop blades.
4.Use a balancer and see which blade of the prop is heavier. Mark it with a marks alot and file metal off on the bow/forward side of the heavier prop blade to make it weigh the same as the other blade. The back edge of the blades should be level, when it is balanced.
