BBY oval master 29 vs. Aeromarine Titan 29..Need opinions
  • cybercrxt
    • 2909
    Hi, I would like opinions of either boat. If they have been tested head to head, etc. I will be using SV27 hardward, UL-1 motor, and Turnigy 120a marine esc. Please let me know which one would be faster, which one would handle better. Just basically any info to help steer me in the best direction. This will be my first FE mono so I am not really familiar with the FE boat offerings on the market! Thanks, Mike
  • Leskimo85
    • Apr 2008
    • 81
    I just ordered a titan 29 and gong to use the UL-1 motor and esc with the SV27 hardware. I had the same dilemma on what hull to get. I chose the titan since it's a fiberglass hull. I think the bby om29 might be faster since it's made out of ABS plastic. So hopefully within the next month or so I'll have her up and running. Not sure if this helps at all!
    • Norman2
      • Sep 2008
      • 321
      BBY Oval Master 29 vs. Titan 29
      Hi. The BBY is a good hull but the Titan 29 is very Superior in Quality. It is Fiberglass
      with carbon fiber reinforcement inside vs ABS plastic. I have a Titan 29 with SV
      power and esc and Fullers hardware. No Oval Master has even come close to me
      in a race. Attached some photos. But really you should get the hull you like if
      the price of the titan is OK which I think it is I would go with the Titan 29. Regards
      Norman
      PS. If you get the Oval Master remember you must reinforce the inside hull with Fiberglass or Carbon Fiber Mat
      34" Ekos Cat UL-1 Powered
      • Tunda
        Eh no steal my slipa
        • 754
        jmo the delta 29 is better then the BBY and the titan..........
        Hawaiian Tunda
        • Norman2
          • Sep 2008
          • 321
          BBY Oval Master vs Titan
          Hi Tunda, I hate to point out that The DF29 has very low freeboard therefore it
          has much less lift than the Titan. Even in aerodynamics the DF29 has that huge
          indentation on top of the front deck which is just a windbrake. They still have not
          beat my Titan 29. Regards
          Norman
          • Rumdog
            • 6453
            haha, Norman........ c'mon man. your boat is very nice. but I know of a lot of DF hulls that will smoke it! especially running only the sv system. the DF has a really long ride pad, and superior aerodynamics. plus it will turn on a dime.
            • Tunda
              • 754
              Yea your right on that may be your boat is set up better then the other guys you race with and you probably Drive better also................
              Hawaiian Tunda
              • Rumdog
                • 6453
                sorry for my seemingly a-hole post..
                • Leskimo85
                  • Apr 2008
                  • 81
                  For hull design I like the Titan. Just seems like it has a deeper Vee and has room to upgrade in motor size down the road.
                  I guess it all depends on what you would like to do? I know I'm not going to be racing. I just want a boat I can take out and run in chop with no problems around speeds in the mid 30's.
                  • Tunda
                    • 754
                    LesKimo85 i can tell you this the BBy that i s for sale Randy built it for me for the rough water it is awsome for that but in the smooth stuff it does not like it too much..... Me and a friend raced a while back and his delta 29 gave me dirty lickens in the smooth water but in the rough stuff he got lickens both boats same set up with SV combo............
                    Hawaiian Tunda
                    • Leskimo85
                      • Apr 2008
                      • 81
                      Yea, for the price I couldn't pass up the titan. Im in school and had to take the one for cheaper price. I really want to get a bby but when the shipping is 1/3 the price of the actual hull. So I had to pass.
