Originally posted by Peter Zicha
View Post
38" H&M Intruder twin to begin
At your service! if you don't get the 1/16" no worry, just if it doesn't slow you down or cause any extra bourbon."Look good doin' it"
See the fleet
Jesse your fronts are machined , your rears are being redone right now . as you can see the reliefs are out way to far . Your fronts have 16 holes for the motor giving you maximum flexibilityAttached FilesNecessity is the mother of invention.............
YOU ROCK, MAN. Just got word (werd.) from the Egneg that my props are on their rockin way, and before long I will be pooling epoxy around my stuffers - indicating that the motors are successfully mounted and thhhhhheeeennnnnnnnnnnnnnnnnnnnnnnnn -- for the roost of all roosts
See the fleet
Jesse
Do you want the mount holes on the bottom the same way threaded 8/32 or how do you want themNecessity is the mother of invention.............
Right, yes same way, but how about 6/32? don't need quite that massive of bolts, thanks for asking."Look good doin' it"
See the fleet
I might also be able to get 1/16 Aluminum in town here some of the hardware stores sell it small strips up to an inch wide
Give me the exact dimensions you need 1/16 x length x widthNecessity is the mother of invention.............
1st rear correction finished the second is milling right now , you can see the difference
I will also see what I can find in 1/16 Alum JesseAttached FilesNecessity is the mother of invention.............
Jesse I appreciate you sending that , it will certainly cover some costs but don't send any more , I will take it from here I want to see this succeed as much as you do . I really felt bad when it didn't come together for you the last time . I have to either make or find a mock 1515 to get the precise angle to trim the bottoms but no worries I have some idea's . This will most likely be send out either Mon or Tues and hopefully I can find some 1/16 here in town....Have a few leads there also...................
Peter, I had a suspicion you would have felt bad, but this is a team design and the players are in different countries, I would have been quite surprised if it had fit perfectly the first time! I appreciate your dedication to this and am sure it will work this time.
Do you want some super precise motor measurements and the cooler can as well? If possible I would like to use the coolers, but really probably wont need em.
Thanks again Peter!!!"Look good doin' it"
See the fleet
Sure sent the measurements , I am still going to build a mock motor to get the exact angle of deflection
thanks JesseNecessity is the mother of invention.............
motor: 2.685" long by 1.535" across
can: 2.190" long by 1.890" across (with nipple: 2.230")
anything else that might help? lemme know.
thanks Peter"Look good doin' it"
See the fleet
Thanks for the measurements , now to go make the fake motor...............
Oh BTW I did manage to find 1/16 x 3/4 x 6 foot flat bar in town so we are stylin there alsoNecessity is the mother of invention.............
