Thanks hookedup! Under the hood is a 2600KV 400DF BL Outrunner, Castle Phoenix 25 ESC (w/Pistix), 1320 3S Thunderpower Lipo and a Hitec S81 Steering servo. Octura rudder, Solinger Strut and turn fin is next to be added...
i got pretty much the same thing in mine, except my Phoenix 25 doesnt need the PiStix. did you try it with out? and mine has octura hardware with an X632.
OPP Racing "Other Peoples Parts!" IslandBoysFastElectrics
I have not tried it without the PiStix...What radio/receiver do you use with it? I will be using a Futaba Magnum 3PM-Fm TX and a R153F RX Or a Novak FM RX.
A side note: Diegoboy runs a modified V935/3 cut down to 32mm. I'm testing a V935/3 razor sharpened and balanced. So far, so good, no issues with the ESC you both are using. Still working with strut adjustments. However, I'm testing an Ammo 2700 running on a Flitepower 1320 3s.
Hey Meniscus! That would be great to try! After several runs with the plastic Octura Y props that I have, I will put on the X632 S/B (not detounged...YET) and see what that will give me. Hopefully things won't heat up too much after a couple of min. run time. Does the V935/3 give you guys any fits temp. wise on anything? Also, what are the average run times with that prop? (before the smoke and meltdown...JK!)
I was trying the 380L in mine, watercooled, but the battery was very painful to get in and out. Diegoboy was kind enough to help me with a bubble hatch to make that happen. I may still try, but I wanted to try the Ammo while I'm working with the adjustments to the strut.
I ran 3s, Ammo 2700kv, Castle 25, V935/3 for 2.5 minutes. No heat to speak of, warm to hot to touch. Without a temp gun, I'd say 95 to 100 degrees F. No water cooling yet.
Hey Miniscus, what motor mount are you using for the Ammo? I like the fact that the Ammo does not get too hot...and that is without a cooling jacket?! is that motor a 380 size?
Keep the info coming...I love it...and thank you guys!
-Kent P.S.- Sorry your old friend is gone, but somebody else will be very happy with it, I'm sure.
