Maritimo build
  • wolf IV
    replied
    D O N E ..........................POWERED HER UP TODAY ON THE BENCH SOUNDS UNREAL, GET HER WET REAL SOON!!!!
    Leave a comment:
  • wolf IV
    replied
    Ok, I recieved the esc coolers today, 8mm leads, and c.f. Plate.. I couldnt wait and cut out the c.f right away. THIS PLATE ACTS AS AN ON/OFF SWITCH AND COVERS ALL THE WIRES. THE WIRES ARE EXSPOSED BECAUSE I DONT HAVE THEM PLUGED THROUGH THE SIDE OF THE RECIEVER BOX YET.. Heres some pics..
    Leave a comment:
  • wolf IV
    replied
    So are you getting tired of running it in the bathtub? or are you waiting for the coconut props from Egneg? I thought you would have had some kinda video up by now...........
    NO , IM WAITING ON PARTS!!!! IM WAITING FOR MT COOLING PLATES FROM OSE FOR; 200 HI MODELS), OR ESC'S (240 REPAIRS)FROM CASTLE CREATIONS..WHATEVERS FIRST..ALSO WAITING ON THE COCONUTS , OH YEAH HOBBY CITY ALSO (8MM CONNECTORS). JUST RECIEVED THE 6XL ! GREAT THANX BUDDY!!! ITS IN KILLER SHAPE, NICE COOLER AS WELL.
    Leave a comment:
  • Jesse J
    replied
    Leave a comment:
  • wolf IV
    replied
    I take a piece of high quality fuel line and cut one side down the middle to fit over the brass but not touching the flex. I then use thick gap filling ca glue to glue it inplace as i squeeze the ends of the hose back together with needle nose pliers. Use kicker or let it set up[... This time i had shrink tube around the brass so the o.d on the shaft was larger and the hose didnt fit all the way around so i used a c.f tube and cut it entirely in half and glued it ontop.. All of this just deflects the grease from spinning off ,.. Worked wonders on my mono you saw on youtube.. Plus looks a little cleaner ..helps with water too..
    Leave a comment:
  • Jesse J
    replied
    Hey Captain CF, you continue to amaze me with your handiwork, could you explain with more pics your anti-grease-all-over-the-inside-of-the-boat trick? I have grease inside ALLLL my boats and would rather not have the truder join in on that fun.
    Thanks
    Leave a comment:
  • wolf IV
    replied
    Originally posted by bonewar View Post
    Wolf , I tried the cnc 3860/3 , It took a long time for them to hook up but when they did the top speed wasn't to bad. the props where cavitating for about 10 sec .I tried to apply the power real slow but it didn't make any difference, I also tried a pair of CF-45,s , The acceleration from the get go was very good but the top end speed was a little slow. So back to the x442's and jump out of the hole acceleration with a much faster top end speed. I have 1 more set of props to try out ( cnc 4569/3) I will try these in the next couple of days. I'm a little pissed about those cnc props being for a tunnel / hydro 1.1m and not preforming , make very expensive show props!!!!! Had the loggers setup in the boat but i forgot to update the software on them so they didn't give me any readings.(f*^$%#k) I'll try that one again soon . Also went down the butcher shop and weighed the boat with everything on board, total weight 4.6kg , Sorry bro no vid wife had to work. so next update I'll have a bit more info for you. BONEWAR
    dude, 10 lbs... thats lite!!!!im at 14 but thats with a crappy scale i have in our bathroomill get a better reading later... im not stoked either as none of my "cnc" props worked either....i bought 3 .... looking good is only cool for a little while.. wish i could use them!!442's it is!!wife had to work? what kinda lame excuse is that? j/k looking forward to seeing it run again!!!
    Leave a comment:
  • wolf IV
    replied
    still waiting on C.C. for esc REPAIRS and decided to try out the himodels 200 amp i use them in my hydro drag boats and love em..i water sealed them with electrical epoxy and am waiting on the cooling plates. i also block sanded the fetts as flat as i could get them without compromising them, still not perfect.. but im using arctic silver 5 compound to bond the plates so it might be fine..i also cut a piece of hose and ca glued it to the heat shrink covering my stuffing tubes and a piece of .... you guessed it C.F. ( my buddy) over the tops for looks...this helped my mono from greasing the inside of the hull and water sealing as well...
    Leave a comment:
  • bonewar
    replied
    Update props
    Leave a comment:
  • wolf IV
    replied
    Ha... Ha... Good to see you bonewar!!!your ears musta beena ringen.... I totally under stand the time issues!! This is why i havent persued my hull design and molds, its just not fun knowing your pissing veryone off around you (the wife) & kids by not giving them your time... The too many hobby thing i totally understand as well.. Ive got my revo 3.3 back running, t-rex 450 up in the air and built and totalled one edf f-35 jet and two 75 mph t-28 war birds all in the matter of 5 months.. Lets not forget almost loosing 3 fingers ..and of course the beutiful maritimo build.. Soooo glad to see you home and i am looking forward to seeing how those props work ( and another video)--- wide open!!!!!!!!im gonna need some competition here.......bring it brother!! OH AND GOOD CATCH=GOOD EAT'N'!!
    Leave a comment:
  • bonewar
    replied
    Wolf , Jesse Sorry boy's haven't played with the timo for about 2 months ( work , wife )Like you guy's I am very interested in those cnc props and how they will go on this size boat. I've been fishing on the coral reef for the past week and now I'm home so the Maritimo is priority No1 . So hang in there and i will have some info for you guy's real soon. I also bought another logger so that i can run 1 each side , should make for some interesting reading. Problem with me is that i have to many hobbies , so between work , wife there is not much time left . Anyway here are a few pics of what I've been up to. I will have an update for you guy's by the end of the week. BONEWAR
    Leave a comment:
  • wolf IV
    replied
    neener neener neener
    Leave a comment:
  • Jesse J
    replied
    No cuts no butts no coconuts..‏
    Leave a comment:
  • wolf IV
    replied
    Coconuts? Did i post the wrong pics??
    Leave a comment:
  • Jesse J
    replied
    hey sent you one back, without coconuts
    Leave a comment:
