Delta Force 33" My Way.....
  • tth
    • Apr 2008
    • 1600
    First I would like to thank Steven for all the equipment, since I purchased 99% of this build from him. I wanted to have this boat water ready for the spring but I have been extremely busy with work. This weekend I started and have made lots of progress. I still need to install external cutoff switch, another set of trim tabs, and turn fins.Let me know what you all think. Enjoy the pics, videos should follow next weekend.
    Setup:
    Tactic 2.4Ghz Tx/Rx
    6s2p 12000mah 25c
    Hydra 240 HV (Need to send in for repair, battery lead fell off????)
    Speedmaster Stinger
    Speedmaster 21 Rudder (JR 148oz Metal Gear Servo)
    2pr OSE Trim Tabs
    Octura x442/x445/x447/x642/x645/m445/m545/m645
    .187 Flexshaft
    8mm x .187 Aluminum coupler
    8mm Thrust Bearing with Machined 8mm shaft spacer
    Neu 1521/1y with OSE H2O Jacket
  • Punisher 67
    Ignore list member #67
    • 1616
    Very nice build Tracy , my next build after the Sniper will be a DF33 with a 1527 and yes build my way
    A video is eagerly awaited
    Necessity is the mother of invention.............
    • Heath M
      • Mar 2008
      • 865
      Very nice build, I like the layout, very neat.
      Heath
      Brisbane,QLD, Aussie
      • Doug Smock
        • 5359
        Good looking build sir!!! That's alot of power for a 33" mono, take a clean pair of shorts to the pond with you, she's going to rip!!!
        Since your control has to go back to Castle to have a wire soldered back on, I would ask them to add some caps to it.
        Looking forward to the vid.
        Good luck with her!!
        Doug
        MODEL BOAT RACER
        IMPBA President
        IMPBA 19887L CD
        NAMBA 1169
        • tth
          • Apr 2008
          • 1600
          Thanks for the compliments guys. Doug thats a good idea.........I'm glad you thought of that (adding caps) . I know its a lot of power but I can always use the added weight of the batts for stability and cog adjustment. Peter I know everything you do is your way. Everyone knows you add your own personal touch. The Sniper is looking wonderful.
          • knpc
            • 649
            That thing will definately be a rocket. I have a df33 with a 1515 1y on 4s2p and it does low 50s. What speeds do you expect to see ? Nice Build
            Rico 29, Sprintcat 34, Insane FE 30 Hydro, 43'' Aeromarine Conquest
            • Flying Scotsman
              Fast Electric Adict!
              • Jun 2007
              • 5195
              Doug
              No kidding on the power. I would suggest you may wish to look at the rudder setback and increase the length or shorten the strut. My 4 Canadian cents. Very nice build
              Douggie
              • tth
                • Apr 2008
                • 1600
                Thanks Douggie I will get an extension milled for the rudder bracket to get the leading edge in line with the drive dog. If all is successful I will keep as is, if not I will start with .75" cut off the stinger and see how she goes then.
                knpc: I have no idea what to expect but I am hoping for 60+/-
                • focused
                  Dutch Electric Powerboats
                  • Jul 2008
                  • 237
                  Wow thats a lot of power for a DF and very clean built, it will fly for sure mine did with a kb45XL8 on 6s and 42x55 grimmracer 52,9 mph and did not need trimmflaps .
                  Michiel.
