startup problem
  • launchpad
    • 199
    startup problem
    hello Guys;
    I am just putting the final touches to my mvegas conversion to brushless.When I hook it all up all I get is a kind of musical tone and thats it.There is no power or what ever.I installed the batteries and then turn the transmitter on then hook the batteries up and all I get is that musical tone.I am a little lost on this one,so I hope there is someone out there that can help me with this issue.
    Thanks in advance......... Al
  • EPower
    • 417
    Hi What esc are you using and did you bid the throttle to the esc ?
    • launchpad
      • 199
      Hello;
      Thanks for getting back to me so soon.I went online to get a description of this esc and it states it can handle up to 8cells lipo.It does not say anything about Nicad or Nimph batteries.It can handle 100 amps continuous with a 15 sec 120 amp burst.Now, am I to assume (hate that word), that it can only handle lipo's.If that is the case then that would explain the problem I am having.You mentioned something else but if I go back to view the answer you sent I will lose all what I have stated here.I know,as I tried and had to retype it all over again.
      What is your opinion on this?I have a few boats and this is the first time I have had a problem with starting of it.
      I would appreciate any suggestions......... Thankyou
      Al
      • launchpad
        • 199
        Hi again;
        I do not follow what you said about bid the throttle to the esc.
        • EPower
          • 417
          Hi i meant did you bind the throttle to the esc
          • j.m.
            • Jul 2008
            • 847
            Some airplane esc's won't arm correctly with a pistol style Tx. This is probably what's going on. See if you can move the neutral point on your Tx.
            • launchpad
              • 199
              starting problems
              hello;
              Well I tried a few things and nothing,I have a hextronic 120 amp esc sitting around and so I decided to use it.The same thing...........I would get a beep and then nothing.I also get the beep by just plugging in the batteries.and the tx off.So i am lost on this,anyone have any ideas.............
              • EPower
                • 417
                It looks like it might be something else same thing cant happen to two esc
                • ED66677
                  • 1300
                  back to the original question... what ESC is this? link?
                  Emmanuel
                  • DISAR
                    • Aug 2007
                    • 1137
                    Did you reverse the throttle channel?
                    http://www.rcfastboats.com/
