Help/Advice first build
  • mmarionz
    • 20
    Hi guys
    So after considering all the RTR's on offer I have decided I would much rather try to build my own boat.
    I have read through the wealth of info but just wanted some confirmation.
    I can get myself a Kb45 8xl 1600kv motor [remember this is my first build I might blow things up].
    Hull is a 39 deep vee weight 1400g [enough motor?] can go to 29 800g weight 0r 33
    What would you guys recommend in terms of a lipo/esc setup?
    I had the etti 150 in mind? with possible motor upgrades in the future.
    http://www.offshoreelectrics.com/pro...i-esc-race-150
    Am I on the right track here
    All I am doing at the moment is sport boating.
    Runtime not speed would be the greater priority.
    Thanks for reading
    Matt
  • mmarionz
    • 20
    hmmmm....guess not huh
    • EPower
      • 417
      Hi there i run a KB45 8XL in an 820 mm long boat about 33 in
      in a 39 in hull i would go for the 10 or 11 xl KB45 and run it on 6 or 7S
      Etti 150race version with the extra cap module wold be just fine
      Cheers Adrian
      • DISAR
        • Aug 2007
        • 1137
        My hull is 36", 1700 gr. weight. Tested on KB45 8XL, 5s with 43-47mm prop, and 6s 43mm prop. Runs fine but with 6s it is faster, but 5s will give more runtime and cooler ESC-motor-bats. The ETTI will be fine.
        The ideal motor as most people recommend would be a NEU 1521/1Y again 6s for speed, 5s runtime, so I would recommend to buy it some time.
        http://www.rcfastboats.com/
        • mmarionz
          • 20
          ok neat thanks guys
          • Flying Scotsman
            Fast Electric Adict!
            • Jun 2007
            • 5195
            What hull, the kb45 8Xl.. No.. look at this motor if you are on a budget
            http://www.offshoreelectrics.com/pro...prod=fei-580-L
            • EPower
              • 417
              Originally posted by flying scotsman View Post
              what hull, the kb45 8xl.. No.. Look at this motor if you are on a budget
              http://www.offshoreelectrics.com/pro...prod=fei-580-l
              LOL What's wrong with the kb 45 at half price of a feigao ?
              • focused
                Dutch Electric Powerboats
                • Jul 2008
                • 237
                You have to do this to get it running save on 6s . Without it the engine heats up faster . But its a very powerfull motor and low priced.
                My 2 dutch euro cents .
                Michiel.
