MHZ Chaparral FE
  • crabstick
    • 955
    #76
    Hi Adrian, what motor did you do that speed with in the Lizard ?
    Matt.
    www.rcboats.co.nz
    • EPower
      • 417
      #77
      What do you think M8 My Favorite motor KB45 8XL same motor i was running before it's my brand new one
      • crabstick
        • 955
        #78
        GO THE KB'S
        Going to wattle in 13 mins to run my cat again!
        Matt.
        www.rcboats.co.nz
        • EPower
          • 417
          #79
          GO THE KB'S
          Sweet let me know how she goes
          • EPower
            • 417
            #80
            Yesterday was the Chaparral maiden voyage I think i have a monster that needs some taming down first run at 31% cog, was way too loose second run at 33% a bit better but i think i need some extra weight here is the vid of the second run just over 60mph when i get it sorted this will do 70 + for sure
            And here is my Lizard Xtreme it just loves the new Hyperion 35C 5500mAh batt, it blows me away every time i run it KB45 8XL must be the cheapest motor on the market but don't let it fool you it's got a tonne of grunt for sure enjoy
            Adrian
            • crabstick
              • 955
              #81
              the only way to describe it would be to call it a Wild Beast. It was just Madness!!! with the power that thing showed on the weekend 80mph would be possible IMO.
              Did you manage to get it to full throttle bro ?
              your lizard would have been near on 60mph too!!
              Go the MHZ hulls!!!
              Nice work as Always Adrian!
              Matt.
              www.rcboats.co.nz
              • Zero_Limits
                • Dec 2007
                • 13
                #82
                Nice work Adrian, good to see the boat run. It sure was impressive!
                Just add another set of lipo's, that should weigh it down, and put less strain on the batts. 11,000mah mmmmmMMmmmMmmm.
                • EPower
                  • 417
                  #83
                  Go the MHZ hulls!!!
                  Thanks m8 i would have been lucky to get it close to 3/4 throttle it was too much of a handful i will add some weight to it and take it out next weekend give it another run
                  Adrian
                  • Gerwin Brommer
                    • Dec 2008
                    • 928
                    #84
                    Adrian !
                    Congrats ! Nice maiden !
                    which prop did you run ?
                    Looks like the boat might like some more weight ( 2P config. :-) )
                    • EPower
                      • 417
                      #85
                      Originally posted by Gerwin Brommer View Post
                      Adrian !
                      Hi Gerwin thanks, that is the prop you suggested X455 i will add some weight to it and work out the right cog, and yes the 2p setup would add about 1.7 kg to it, it needs at least that much i have a question for you i could not get that esc to work on HRS mode only on PPM i would like to run hrs because i'm running a Digital servo any suggestions ?
                      Adrian
                      • Gerwin Brommer
                        • Dec 2008
                        • 928
                        #86
                        The esc and the TX-RX signal are worlds apart.
                        HRS/PCM/PPM ONLY tells you something about the "signal-traffic" between transmitter and receiver. The esc doesn't care which RX " feeds him".
                        • EPower
                          • 417
                          #87
                          Off to the pond again tomorrow i got a 2kg (4 pounds) lump of stainless steel mounted in the boat Cog at 35 now
                          • G Doggett
                            • 477
                            #88
                            We were all mighty impressed by the speed and build quality of both of your boats on the weekend mate.
                            Keep up the great work.
                            4lb of stainless steel ballast up front , just remind me to stand well back from the bank !!!
                            I'm even more motivated now to do a big twin electric conversion on my Victory cat.
                            By the way, what's that little cat sitting on top of the Chaparral, have you been shopping again ?
                            Graham.
                            • EPower
                              • 417
                              #89
                              I'm even more motivated now to do a big twin conversion on my Victory cat.
                              Graham.
                              Thanks M8 would love to see you do a big FE cat it would be another work of art don't worry that big lump of steel won't go anywhere
                              The cat is called a Baby Freya
                              I want to run one of these in it on 4s
                              Cheers Adrian
                              • EPower
                                • 417
                                #90
                                Hi been busy with other stuff, changed a few things on the Chaparral, batt between the rails now can get up to 36% cog if i need to, ESC further forward, carbon batt tray, hopefully i can tame this beast this time around might try some smaller props too here's a few pics
                                Cheers Adrian
