MHZ Chaparral FE
  • Flying Scotsman
    Fast Electric Adict!
    • 5195
    No direspect but plywood I think would work better than CF for the transom and applied as Gerwin mentions.
    Douggie
    • EPower
      • 417
      I can get all the CF i want for free and in my opinion it is much stronger
      Adrian
      • Flying Scotsman
        • 5195
        The only problem I see with CF on the transom is the pressure and strength required to bolt the fasteners and IMO plywood is better and will provide also more strength to the transom..no flexing, we hope
        Douggie
        • EPower
          • 417
          Hi Douggi
          the CF i used for the transom and rails is 3mm Cf plate made with prepeg cf matting that is vacuumed and cooked in an autoclave this process makes it so hard that you can't cut it with a normal hacksaw it is then glued with HPR5 glue we use this glue to join CF mast shells together
          so i guess if we are talking about how flexible or how strong it is i know witch way i would go M8
          Cheers Adrian
          • Flying Scotsman
            • 5195
            Adrian, "I will say no more" as you Kiwis know a bit about building boats and my knowledge of CF is related to motor racing. I was of the belief it could not take a sharp side movement without shattering.
            Douggie
            • EPower
              • 417
              Hi Douggie
              Believe me this stuff is really strong if you ever want to try some let me know
              Adrian
              • Gerwin Brommer
                • Dec 2008
                • 928
                Douggie :
                Let say it this way : If I was in the same position as Adrian I would NOT consider the ply .
                Adrian : I don't know of ANY European using thrustbearings on motors.
                I always am surprised that almost every American/Canadian/Australian boatpilot uses
                thrustbearings ! We never use them.
                IMO a thrustbearing is EXTRA friction ( as long as the rest of the setup is used/installed correctly )
                • Gerwin Brommer
                  • Dec 2008
                  • 928
                  Yes , I know. And I don't care . hahaha
                  Adrian : spread tow carbonfabric ?? !! NICE !!!!!!!!!!!!!!!!!!!!!
                  • Flying Scotsman
                    • 5195
                    [Adrian : I don't know of ANY European using thrustbearings on motors.
                    IMO a thrustbearing is EXTRA friction ( as long as the rest of the setup is used/installed correctly )[/QUOTE]
                    Gerwin, that will upset the applecart and Gerwin's last response was to a message, I deleleted due to bad spelling. The context was the same and Gerwin I loved the reply , If you still have access to my deletion post it
                    Douggie
                    • Gerwin Brommer
                      • Dec 2008
                      • 928
                      Douggie said that my opinion about thrustbearings will start an
                      intercontinental-war, haha.
                      There are more funny differences between your boats and our (European) boats :
                      * you guys put rails in FE boats, we don't
                      * you guys use S-bends pretty often, we try to avoid them
                      * we always try to use direct-drive, you guys "often" use "gears/pinions"
                      • Flying Scotsman
                        • 5195
                        Here is my original reply..... I can not post it but Gerwin's response is correct
                        Douggie
                        • Flying Scotsman
                          • 5195
                          * we always try to use direct-drive, you guys "often" use "gears/sprockets"
                          Gerwin, S bends are a no no. Rails are OK based on the power plant and setup for the electronics. Most guys are now using direct drive.
                          And back to topic
                          Douggie
                          • Gerwin Brommer
                            • Dec 2008
                            • 928
                            Yeah, please back on topic !
                            The beautiful chapparal deserves it...
                            BTW : Adrian, the cayman in the movie is running 2x !!! 32 cells.
                            that's why it behaves so nice. There also is a movie with 1x32 cells, same boat, but then it behaves completely different, due to the lack of weight.
                            • EPower
                              • 417
                              Wow lots of good questions and reply s here that's all good i think the thrust bearing idea is gone out the door now
                              in my opinion the guys in Europe have done so much FE stuff that we have to really listen to them i guess that's wy i ended up using their motor & ESC no disrespect to my American friends
                              Gerwin and Duggie what size prop should i run on this setup
                              Cheers Adrian
                              • Flying Scotsman
                                • 5195
                                Gerwin over to you, I have no knowledge of this hull and proposed power BUT I might suggest a 645 to start
                                Douggie
