Its not coming from the jacket. It seems to be coming in somewhere at the rear. I chopped the hell out of the inner hull. I had removed the whole molded in radio gear box, and below that is where all the water is. I will have to tape the hatch up better or something else. I also have a problem with the teflon tub not staying put. It always goes back. I think I might just epoxy the sucker in place. I am also going to try a 42mm prop and see what that does. I had run a 40 in for the first 2 times.
Purple Light Super Hawaii Knock Off build
Go with the x445 prop. You will be happy with it. Put a sponge in the back and run it one lap and check to see what kind of water is in there. As far as the teflon tube, are you talking about the one in the drive line? I stuffed it in there till it bottomed out and then cut it up by the motor. I have about 1/2 inch hanging out. Make sure you tape the hatch all of the way around. Narrow down the prob it can be on the water leak. C
