Do they differ or are they the same as riggers? => I'm trying to understand Joe's post about "dihedral angle"
Now accepting Canard plans
the more dihedral you put the less fin you need but the deeper sponson will ride!
I took a few pics of the underside of mine for you.
With regards to turn fins I run a small one on the rear of the front sponson.
The dihedral angle & the angle of attack on the wings & sponsons were completely arbitrary on my part. They just looked about right on paper.
As you can see she's got a few battle scars & needs a repaint. One day.
Love those canards Joe. Great pics.
All the best.
Paul, Great pictures, this helps a lot. Could you post a picture with a profile view? I am interested in seeing the orientation of the strut in comparison with the ride surfaces in the back.
Andy, No I haven't talked to him yet. Send me his contact info please! Thanks.IMPBA: 7-Time FE World Record Holder "Don't think outside the box. Rather, refuse to admit that the box exists in the first place!"
Also, what is the relationship regarding the width of the step in the front and the ride pads in the back?
Is there a general calculation related to the distance of the front step and the distance between the sponsons in the back? Or is it just what looks good? LOL!
Last, I'm thinking that, due to the difficulty setting up a Canard, I may consider making the three wet surfaces adjustable for angle. Has anyone done this already?
Keep the information coming guys! Before long, we'll have H&M making a fully adjustable one
LMAO! => as if the demand was there for fully adjustable Canards!
I didn't see any canard hull bottom photos. I don't think its terribly complicated but a hull that you can change sponsons easily would be the ticket. The angle of attack looks to be in the 3 to 5 degree range and the dihedral looks around 15+ degrees.
Now that I have got mine going a lot better with advice from ED and others.
I will take a few pics and then draw some dimensions on them too.
A big difference that my Canard has is a narrow nose, if you have seen my build and run thread then you will see this. I don't really know if it is good or bad as I have only ever seen my Canard run. I have seen a few on the tube and the smallest is a 12cell or 4S beast that is Pauls. (785boats). Mine is a 6-cell or 2S size.
Give me a few days to get the pics up and I will get them "painted on" and then post them here. I can e-mail the hi-res ones to whoever wants them.
PM me if you want them so we don't cloud up this thread.
Ben , you automatically get them sent to you.
Joe, that's why I'm thinking adjustable. This way, some determinations can be made regarding what does or doesn't work, without going through build after build.
Teach, thanks for the link. Wow, there are a lot of plans there...more than I know what to do with, LOL.
Simon, I'd say post the pics, it may help someone browsing later.IMPBA: 7-Time FE World Record Holder "Don't think outside the box. Rather, refuse to admit that the box exists in the first place!"
Next question for pondering:
Steps? Since it has been explained that the Canard works on principles similar to a tunnel, does/has anyone used steps on the ride surfaces? Good idea/bad idea?IMPBA: 7-Time FE World Record Holder "Don't think outside the box. Rather, refuse to admit that the box exists in the first place!"
Hi there.
Here's a side view of the ol' girl. Also one taken slightly above & one from slightly below side on.
There's also a top view. I managed to find the original sketches & took a photo of them. Not very clear I'm afraid but it may help with some proportions.
As I said before I based the thing on a photo of the Aeromarine canard & all dimensions, angles & proportions were just what looked aesthetically pleasing to the eye. Well, my eye that is. So There are probably many design rules broken or ignored in this model.
The only thing that I feel is important is to get the COG as close as possible to the center of lift. My previous experience with building model planes convinced me of this.
Regarding the ride pad of the front sponson, you'll see that mine tapers to a section of about 30mm wide where the small turn fin is attached ( see previous photos )
Once the boat is set up The front sponson barely kisses the water at full noise so I don't think its size is much of an issue. But for sure, the smaller the better is always a good target.
If steps make Hydros, Tunnels, Monos & Cats go faster I don't see why they wouldn't make a canard go faster too.
I don't have a clue about what it will do to the handling though.
Here's the dimensions of mine if it's any help.
Length: 700mm (27-1/2")
Width: 440mm (17-1/4")
Rear sponson length: 300mm (11-3/4")
Rear sponson width: 70mm (2-3/4")
Front sponson length: 200mm (8")
Tub width overall: 110mm (4-1/4")
Tub width internal: 75mm (3")
Hope this helps a bit
Great pics Paul! These pictures are some of the most useful thus far, especially for setup. Great info as well regarding dimensions.
I guess I may have to be the guinea pig for steps. In any case, I'll make the sponsons removable and have two different versions, courtesy of Joe's input.
Say, is that a full book of plans you have drafted? Perhaps we may have to talk about making me a xerox copy
LMAO!
Too true. Now I'll have to make a real effort on my pics.Originally posted by Meniscus View PostGreat pics Paul! These pictures are some of the most useful thus far, especially for setup. Great info as well regarding dimensions.
My call would be go for "plain" sponsons first and then if as you suggest they are easy to modify then throw on the steps later.Originally posted by MeniscusI guess I may have to be the guinea pig for steps. In any case, I'll make the sponsons removable and have two different versions, courtesy of Joe's input.
That looks like the last page there Ben, I think Paul is a bit like me and has 90% of the build in his head and the rest is scribbled on a piece of paper.Originally posted by MeniscusSay, is that a full book of plans you have drafted? Perhaps we may have to talk about making me a xerox copy
LMAO!
In my workshop at the moment I have a lot of pics of a Xcess-3 riggerSee it....find the photos.....sketch it it....build it........with wood
Yes, I was planning to start with plain and go from there. I like lessons-learned in stages, LOL!Originally posted by Simon.O. View PostMy call would be go for "plain" sponsons first and then if as you suggest they are easy to modify then throw on the steps later.
