through out the 2008 year, bought most of this from Steve here at OSE. hope you enjoy. keep in mind this build is not perfect but should do me well playing around the lake.
robby76 Jolly cat build
now if the wind would calm down so that i may start running.
Nice job! That looks like a KB45? And is that the Jollycat hardware or what brand?
I especially like the nice pink ribbons on the hatch! I definitely support it! I might have to steal that idea...My prop hasn't been wet in a while.
Nice job. What is your setup?Twin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
http://www.rcfastboats.com/
yes, KB45-8L. strut is Solinger long w/bracket, rudder ??? left over from another project. made the extension out of flat aluminum. octura hardware, GrimRacer prop 40-57/3. bare jolly cat hull no motor mount.
except for the esc, LIPOs & related charging equipment, ALL was bought from Steve here @ OSE.
the LIPOs are 4S & will parallel two to the HM200 esc
the esc is encapsulated in DP270 with water-cooling plate and side water tubes.
the radio is FM Hi-Model.
the hull was very clean with no blemishes on it. plan on buying another one soon.Last edited by robby76; 02-18-2009, 11:12 PM.
well today as my son and i were getting ready to go to the lake, hooked up LIPO power to check rotation of prop so that would be one last step to check at the lake.
ruder worked great, when hit the throttle esc turned cherry red then EEEERRRTEEEERRT the inevitable famous sound.
biggest fire i've seen...and in the house. we did get the boat outside and luckily got positive lead off to stop it.
have checked the rest of equipment. all ok will be getting another esc.
am using two of these same HM200s with no problem.
Just a note. I encapsulated my HM200A in DP270 and the ESC lasted for about 30secs with the boat in the water. I will never encapsulated again and using other ways.Twin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
I start believing you must be quite lucky with the HM200A. Some work very well, some don't and they just burn.Twin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
i agree. have two others that perform excellent with one being encapsulated. i think it was a quality control issue. i bought this 6 months ago and has been shelfed until finished with project.Originally posted by DISAR View PostI start believing you must be quite lucky with the HM200A. Some work very well, some don't and they just burn.
i don't find any arcing on water plate which was blown off.
also, glade for the 12 coats of clear on hull.
next project, esc will be the last item to purchase a week after it is complete.
enjoy the pics here.
i really thought i was going to burn down my house.
That's a nice looking cat you have there.
Ewww, hope your house doesn't have that burned ESC smell.Paul Upton-Taylor, Greased Weasel Racing.
thanks.Originally posted by NativePaul View PostThat's a nice looking cat you have there.
house and garage have that ESC smell. mrs wants to call in "Service Masters" !
i'm like...i need that $money$ for another ESC.
The only different thing i did here is I added an extra positive lead with a 47 ohm resistor to minimize the in rush voltage charging the caps. might have inteferred with the default settings.Attached Files
since the KB motors are physicaly large and not having a programing card using the default settings, motor timing could have contributed to this failure.
the other two HM200s are on Feigao motors.
"WARNING: For some large motors, you must use High timing mode. Failure to do so will result in a burnt esc."
also, my wife chewed me out royaly
