Can we get a set from oyu e-mailed? Is it tiled plans or what.
I want a winter project to build a new cat with twins, etc.
OK I got a lot of plans from every one. I chose the one that i thought would work for me. i took the plans to staples and had them blowen up to 70'' then got the supplies and started the project. however do to the lady at staples messing up the process of blowening up the plans do to the large size, non of it came out right. so when i started to cut the wood for the hull i found some of the parts were the wroung size for each other
. so iam back step 1 and starting over, now i got to find a store that can blow up the planes the right way.
HI agian for a 72'' cat what wood should I use??
so I PLANE on going Big at lest 70 mpa
. but iam new to electronics and boat building so it will take some time. i hope to be done in 6 month's. first i will build the hull out of wood then make a mold out of it. i will keep the wood hull and finsh it but have a fiber glass plug as a back up just in case. any advice you can give is more thin welcome and i was thinking of useing twin 1/8th scale Mamba Monster Brushless moters with lipo
