Sport 40
  • egneg
    • 4664
    #46
    Job well done! Is that a Prather 225s or 230s?
    IMPBA 20481S D-12
    • andym
      More Go Than Show Prop Co
      • 2406
      #47
      It is the 230s Chuck, nice spotting! Thinned to within an inch of its life and just a hint of edge cup. Should rip on 8s with a the 1050kv feigao 580 xl.
      • ksm2001
        • Jun 2007
        • 377
        #48
        That is one very HOT looking boat Andy, VERY nice
        Ken
        • andym
          • 2406
          #49
          Well an update is in order, first run with Hyperon 4s 35c x 2 packs in serieies for 8s, CC Hydra HV 240 and the Feigao 580l 1050Kv motor. Ran hard but a bit wet, heat OK changed T/Fin angle and lifted strut to 16mm from 20mm. Boat launched hard , turned even better and was well over 60mph.
          They are an impressive sight at full flight.
          Came back in and checked temps, esc & packs OK motor a bit warm. Changed to a x447/3 blader , what a blast , out of the hole like lightening and very quick.
          Then BANG one CC HV 240 up in flames!! No damage to anything so I consider myself lucky.
          Back to CC with this one
          If any of you high volt guy's would care to share your motor, esc and prop set ups I would appreciate it very much as this is my first HV application.
          • Xzessperated
            • Apr 2008
            • 3060
            #50
            Sorry to hear that Andy. It has not been a good year for you.
            • egneg
              • 4664
              #51
              Bummer Andy - sounds like the 447/3 may have been to much prop?
              IMPBA 20481S D-12
                • 7990
                #52
                The x447/3 is a HUGE step up from the the P230, with 33% more blade area and load, but with LESS pitch (2.6" versus 3.0") so a lower speed potential. Perhaps a better step up for more speed would have been an P235. More pitch makes the boat faster, more blade area can increase acceleration but limit top speed.
                • andym
                  • 2406
                  #53
                  It was Faster with the 447/3, no question. I can run one on my 4s mono over race distance with similar total rpm so I assumed that with the higher volts and lower KV it would be Ok. The old pitch versus blade area thing,,,,,,,,,,,,, I have more fun with larger props with less pitch as they get out of the hole better off a turn and due to the size seem to stay hooked up in chop better.i have found the amp draw between say a m645 and a m447 similar but the 447 a better all round prop.
                  I do not think it would have been over 180 amps as the packs were not even warm
                  • crabstick
                    • Jul 2008
                    • 954
                    #54
                    always sad to hear of an esc going
                    Specially when it really shouldn't.
                    Are you going to get another Castle ?
                    Matt.
                    www.rcboats.co.nz
                    • andym
                      • 2406
                      #55
                      Only if they replace it under warranty, I got it off of TTH (Tracy Hatch) it was brand new purchased by him and forwarded to me.
                      • DISAR
                        • Aug 2007
                        • 1072
                        #56
                        Probably your ESC did not burn because of the high amps but because of the wire inductance. This is helpful
                        Electric General Discussion - Max wire length between motor and ESC? - I've seen a few discussions on this topic, the maximum length that the wire between a brushless motor and ESC can be . I'm looking for a concrete answer, based on REAL electronics engineering fundamentals, not old wives tales (don't tell my wife I
                        What I understood is
                        a) As short wires as possible from bats to ESC (max.12" total)
                        b) Close the positive-negative wires loop by attaching the ESC wires together.
                        Sorry to hear your loss, but they say that CC is good in replacing ESCs
                        http://www.rcfastboats.com/
                        • andym
                          • 2406
                          #57
                          The wire length is as follows, battery to esc 105mm, esc to motor 50mm. 5.5 bullet conectors. Packs, + to neg and then + esc, neg esc to series the cells. I have been doing this hobby for some time and the only CC esc to *!***!***!***!** itself is the CC120. Just a poor esc the 240,s I have are great and I was hoping all the negative reports on the HV 240 were user error but I gues not. Should have got a Shultz!!!!!!
                          • jingalls007
                            • 1015
                            #58
                            I would think with a HV setup 8mm bullets might help to carry some of that current. I think 5.5mm bullets are to small for that power.
                            • AntronX
                              • Jul 2008
                              • 333
                              #59
                              Yea, I thought like that too. After burning through a bunch of Hydras I finally got my new 40/160 running last Sunday. Should have listened to experienced guys over here who told me to get Shulze right away, back when I was experimenting with cheap Chinese controllers. I must have burned through over a grand. Could have had two 40/160s with that money I wasted.
                              • andym
                                • 2406
                                #60
                                Yes I must agree, where are the experianced HV guys? Any imput is greatly appreciated.
