Titan 29 Refurbish
  • Norman2
    • Sep 2008
    • 321
    Titan 29 Refurbish
    Hi, Just installed an SV27 brushless system which I got from Steve at OSE. Using
    the same X447 prop I was amazed at the increase in speed. Also changed the
    name to get ready for this season in our clubs new LSO class with BJ, SV, or UL-1
    powerplants. Should go to lipos but do not know what pack or packs to get.
    Norman2
    34" Ekos Cat UL-1 Powered
  • properchopper
    rcgoatbuild@snotmail.com
    • 6958
    Great job. Love the windshield treatment. Go for the most battery capacity you can; Offshore runs 4-minute heats and the Titan needs some weight to keep from getting too loose; the hull loves to air out ! I've set mine up with the UL-1 powerplant & am testing with some older Poly RC 4900's in 4S2P arrangements and smaller props to get the best combo of speed & runtime.
    • calcagno45
      • Mar 2008
      • 1006
      Nice job!
      I like the name! Shake and bake!!
      You can call me the Magic Man...
      (I'm hoping you got the idea from Talledega Nights)
      • Flying Scotsman
        Fast Electric Adict!
        • 5190
        Cool looking boat. Look at Tony's reply on props. I think an X447 is too large.
        Douggie
        • properchopper
          • 6958
          Like Douggie said, a smaller prop, or a cut down bigger one may be better. You'll find that the Titan's extreme deep-V and it's tendency to air out may cause some torque roll in straight running as well as affecting the ability to negotiate the left turn[s] in an LSO course. I'm still working this out with mine.
          • Norman2
            • Sep 2008
            • 321
            Titan 29
            Douggie
            Thanks Douggie, Would you reccomend an X442 or X445. Thanks for your help.
            I used to use an OSE 700 sc motor with the X447. Thanks again
            Norman2
            • Flying Scotsman
              • 5190
              Norman, frankly the only way to tell is when you change to LI-PO batteries is a lot of trial and error with your setups and watch your temperatures or else use an Eagle recorder which is way more accurate.
              Douggie
