New build 35inch Delta force 3s Only
  • Bmwmick
    • Jun 2020
    • 12
    Hi Guys
    I am new to electric
    Building a Delta force 35
    I can run any Motor and ESC but Only
    3s Battery
    What Motor and Prop would you guys recommend I was thinking around
    2700 to 3000Kv but open to suggestions
    Regards Michael
  • Bande1
    • Mar 2023
    • 678
    2500kv prolly be better.
    • photohoward1
      • 1781
      He said 3s....go with the 3000kv.
      • Bande1
        • Mar 2023
        • 678
        3s in a boat that size will go about 40mph +/- putting him in prop size of 36mm. 2500kv puts him in the 43mm range.
        • Peter A
          • 1622
          Series your 3s batts to 6s, run 1300-1600 kv. If you don't over prop you can easily run an OSE Raider 150 esc. 6s will give you better speed, cooler temps and longer runtime in general.
          • Bmwmick
            • Jun 2020
            • 12
            I can only run a maximum of 3s voltage wise
            Can run 3s 10800am pack if need be
            I wish I could run 4s or even 6s as I have these
            I all ready run in other classes
            Now have to go out and buy yet more
            Batteries [emoji23][emoji23]
            • Bmwmick
              • Jun 2020
              • 12
              What size Motor would you recommend
              I have 200amp and 300amp ESC I can use
              • Bmwmick
                • Jun 2020
                • 12
                I went with a TP4060. 2620kv will try on a 43mm prop
