OSE Raider XL 53?
  • pescador
    • 503
    OSE Raider XL 53?
    I am looking for any feedback on the 53 inch Raider hull, I have not seen any builds with it.
    I need to replace my old Twincraft for 10S heat racing in Open Mono.
    Thanks all.
    Namba District 16
  • pescador
    • 503
    OSE Raider XL 53?
    Originally posted by BennettWinslow
    You might be one of the first to test it for 10S heat racing! From what I?ve seen, the Raider XL 53 has solid construction and good lines for stability at high speeds, but it's not widely used yet in Open Mono setups. Might need some tuning to dial in the CG and strut height for heat racing. If you're replacing a Twincraft, it could be a worthy upgrade with the right setup. Let us know how the build goes?keen to hear results!
    Thanks a lot for the feedback, I ended up going with the 53 inch Delta Force Annihilator. I was not to sure about the Raider I could not find any builds at all.
    But if it runs as good as the M34 it would be pretty sweet.
    Anyway I just finished the Delta Force with a full cf inlay and a bulkhead under the front deck. Hopefully it can handle heat racing against the gas and nitro boats.
    Namba District 16
