Rico Superboat Plan
  • Brothers 1718
    • Jul 2017
    • 132
    #46
    Originally posted by Bande1 View Post
    so it easily handles a lot more. you can also double up the shunts by wiring them in parallel. run these on my 12s cat pulling 295 peak amps. SMC have about the highest rated output of any battery. They put out about 200A at storage voltage. so if you are doing laps that's about what you want to prop for at the most.
    I didn't think of that, that is an interesting idea.
    • Punisher 67
      Ignore list member #67
      • 1616
      #47
      Hi
      Running a bit behind on your mount but should be done tomorrow , I will post a picture with my 30100 mounted inside
      .I still need to mount ESC plate and drill and tap side mount screws , there is also a black silicone tube at rear to cushion back of motor in mount . if you roll back to previous picture you will see it on mounts I posted .
      Peter
      • Brothers 1718
        • Jul 2017
        • 132
        #48
        Originally posted by Punisher 67 View Post
        Hi
        Peter
        Oh wow, it looks so good. I'm excited to see this in person. The rubber cushion is an amazing touch. I never would have thought about putting something like that in a motor mount.
        • Brothers 1718
          • Jul 2017
          • 132
          #49
          Boat looks great , Any decision on motor and esc .
          I just realized I never answered this question. I'm going with the ZTW 500 amp. Is it overkill? Most likely.
          • Punisher 67
            • 1616
            #50
            Done - your mount is complete , Jeez I will have to make myself one also.
            Jesse - You will need to put a bit of dish soap on the rear of the motor to slide the rear of the
            mount on with the black silicone tube cushion ....... Its pretty snug !!
            • Brothers 1718
              • Jul 2017
              • 132
              #51
              Wow, that looks so good, the purple and the silver just pop.
              • Brothers 1718
                • Jul 2017
                • 132
                #52
                Also, what is that on the back of your motor? Is it so that the wiring configurations are interchangeable? If so, that is simply brilliant.
                • Punisher 67
                  • 1616
                  #53
                  Yes that is correct , makes it easier switching back and forth from Delta or Star .
                  I have done all my Lehners this way
                  • Brothers 1718
                    • Jul 2017
                    • 132
                    #54
                    I had a feeling. Did you make those because if you did ....... can you make some for me please?
                    That is the smartest thing I've seen all year.
                    What size bullets do you use?
                    • Punisher 67
                      • 1616
                      #55
                      Do you have 3 wires out your back or 6 on the Lehner
                      • Brothers 1718
                        • Jul 2017
                        • 132
                        #56
                        I'm running 3, on second thought, it doesn't make any sense.
                        I'm using the LMT solder straps for the delta wind. I am a little worried about them, as they only take 6mm bullets; shouldn't I be using something larger for something pulling this many amps, like an 8mm?
                        • Punisher 67
                          • 1616
                          #57
                          I am hoping Tyler chimes in here as he is the Lehner expert . What wind is you 30100.
                          • Brothers 1718
                            • Jul 2017
                            • 132
                            #58
                            My wind is a 6.
                            • Punisher 67
                              • 1616
                              #59
                              I use 6mm connectors and mine is a 7 turn . The 500 amp ESC you are going to use is a good idea and good insurance. If you could solder on 8mm connectors those would easily take the load .
                              • vvviivvv
                                • 1148
                                #60
                                I'd take LMT 6mm bullets over any other 8mm bullets..
                                Uk SAW record holder
