Warning: Trying to access array offset on value of type null in phar://.../vb/vb.phar/bbcode/url.php on line 2 Warning: Trying to access array offset on value of type null in phar://.../vb/vb.phar/bbcode/url.php on line 2 What props to use - Rc Boaters Forum
What props to use
  • aussiemick
    • Mar 2015
    • 8
    What props to use
    Hey Guys
    Building a 114 twin cat , using SSS 4092 1650kv motors. 220 amp swordfish speed controlls.
    Using 6s batteries
    What props would you use. Not chasing huge speed , wanting a safe set up to start out with.
    I am newby to boats.
  • koen
    • Mar 2020
    • 366
    start with cnc 4619 to start with(2 blade)
    • Bande1
      • Mar 2023
      • 678
      safe starting point
      https://www.offshoreelectrics.com/pr...od=cnc-4314250
      https://www.offshoreelectrics.com/pr...=cnc-4314250-R
      • aussiemick
        • Mar 2015
        • 8
        I have found 2 sets of cnc props.
        4616 2 blade 1.6 pitch
        4714 2 blade 1.4 pitch
        Both are sold as a pair.
        4619 are not listed on this website.
        • koen
          • Mar 2020
          • 366
          oh yeah the xx19 prop are from TFL, the TFL dealer in germany has all the seizes props from 1.4 to 1.9 (but the 1.9 is only 1.2 pitch it's a graupner copy)but if you start with the 4714 it's a good start
          • Bande1
            • Mar 2023
            • 678
            in this thread he is using 4816 on a much smaller twin cat (36") with more powerful motors and pushing it to its limits. he includes data log to confirm.
            https://forums.offshoreelectrics.com...ger-Cat-Update
            final pitch:
            60mm for long oval lapping
            65mm for bashing
            70mm for speed runs
              • 4335
              Since both the boat and driver are new, I would suggest you start with a prop similar to an Octura 447 (47mm diameter, 1.4 pitch ratio). Because you've chosen a mid range motor kV that is well suited for 6S running, you'll ultimately run a slightly larger diameter when looking for more speeds.
              • aussiemick
                • Mar 2015
                • 8
                Thanks guys for the info.
                Will order a set.
