Ok guys I have both motors now, which one should I go with??
New xxx from aeromarine
Some progress was made. I messed up and drilled the hole for the steering arm on the wrong side but luckily speedmaster makes a dual arm steering horn which will remedy this.
Hi, where can I get one of those carbon hull to buy xxx?Originally posted by BlakeT View PostBuilding a new xxx hull (even got the mini version) Troy did a great job running full length carbon. I have purchased everything for the boat so far other than an esc and motor. Going to start rigging it soon. I?m not sure whether I want to use a tp5680 800kv on 12s or my lmt 3080/7 on 10s. The lehner may not suit me as I am looking for 80mph and I?m a little scared to burn up that expensive motor.Do you know what the biggest problem with the world is?
That the Smartest people are full of doubts while the stupid ones are full of confidence.::tt2
Little progress made, motor is now mounted with the ends soldered as well as the coupler mounted. Next up is stuffing tube and cable
Mounted some carbon plate and started fitting the servo
That is the side it should be on for racing.Originally posted by BlakeT View PostSome progress was made. I messed up and drilled the hole for the steering arm on the wrong side but luckily speedmaster makes a dual arm steering horn which will remedy this.
When you push on the steering rod it flexes, it can not flex when you pull on it.
Blake I have a couple of new in boxes 12S -ESC's in the for sale forums.
LarryPast NAMBA- P Mono -1 Mile Race Record holder
