I have always noticed and wondered why sport type hydros "require" so little setback on rudders and struts because every variation of strut and rudder is available in both mono (longer) and hydro (shorter) setbacks. I understand of course the effective hydrodynamic hull ends at the sponsons, and the remainder is only aerodynamic afterplane and the transom hardware mounting area. Hence the "3-Point Hydro" designation.
So what would be the result if you simply ran the ~3/4" (?) longer mono setbacks on a hydro? Wouldn't it be a little more stability as a result of an effectively longer 3-point hydro? Less tendency to blow off? More rudder authority? Or would the result be negative for some reason? Are 1/8 scales limited in strut setback (under the hull) to disallow taking advantage of this potential benefit? Or is that just for scale appearance?
