Adhesive for fiberglass hull
  • ken webb
    • Oct 2010
    • 69
    What type adhesive is best for gluing stringers into a f/g hull. Cloth is lot real smooth.
  • jkflow
    • Aug 2021
    • 329
    Clean and soften the existing surface up with acetone.
    Any epoxy glue will work, suggest 30min epoxy to give some time to adjust and not get in a hurry. JBWeld works as well.
    The must-do is the acetone wipe down to soften the existing epoxy.
    Measure, line up, do this about 20 times to get it right and finally jump into it. Make sure everything is straight and no binding or offset to the motor.
    • koen
      • Mar 2020
      • 367
      you also use West epoxy and you can if nassesery thicken the reasin with glass bubbles
      • ken webb
        • Oct 2010
        • 69
        Thanks fellows. That what I wanted to know. Haven't done much f/g work.
        • TRUCKPULL
          • 3293
          If you are using Plywood - Use the West Systems Epoxy.
          Larry
