Time for another build log of a F1 tunnel hull. I designed and built the Cozy F1 Tunnel 7 years ago already. The build log can be found here:
https://forums.offshoreelectrics.com...nel-wood-build
This time I designed a 32 inch hull. Setup will be 6S with a 3674 SSS 1650kV motor and 120A esc.
It will be an outboard setup with TFL large leg.
Speed estimate / goal is 55mph.
I took my experience from the Cozy F1 into the T800. The sponsons are wider and have less angle, to improve cornering. The hull and sponsons have a seamless deck and the tunnel has a lowered bottom, just like the real F1 Tunnels.
The hull I designed in Autodesk Inventor. I plotted the drawings and started to cut the ribs.
First update:
Verstuurd vanaf mijn SM-G970F met Tapatalk
First update:
