best way to secure a sleeved stuffing tube
  • mrd72
    • Oct 2021
    • 70
    Decided on going without a teflon liner for my 1/4 flex shaft, so I sleeved 5/16 into a 3/8 tube, its stainless tubing so was wondering what would hold the smaller tube in place? was gonna solder it, but stainless is a PIA to solder. its a close fit, so not sure if epoxy will hold if it just gonna get pushed out when inserting smaller tube or maybe use a loctite?
  • longballlumber
    • 3417
    a clamping shaft collar on the sleeve OD would work.
    McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
    • jkflow
      • Aug 2021
      • 329
      Loctite 603 retaining compound. Easier to handle and breaks when heated up.
      • Panther6834
        • Apr 2020
        • 708
        I second the Loctite Retaining Compound, although I use Loctite 648. The biggest difference between 603 & 648 is that 648 had a high-temperature resistance, so it won't fail in high-heat areas. Due to possible high temperatures in the stuffing tubes, caused by the super-high rotating speeds of the flex cables, that's what led me to go with 648.
        ~ More peace, love, and kindness would make the world a much better place
