Paint for a Prather Hull
  • JohnZ
    • 267
    Greetings all, I got a hold of a Prather 31" Deep Vee hull and could not find any paint recommendations for the hull. As the hull is epoxy glass I would think that nothing really expensive needs to be used. So would a brand like Rustoleum or maybe an auto spray paint can be used? I've used krylon on an ABS hull with good results but with this one there should be more than one choice.
    Suggestions, comments, concerns?
    Thanks
  • Panchothedog
    • Oct 2015
    • 173
    I have used Rustoleom paint over primer of the same brand on glass hulls with no problem. Just remember that the spray paint is kept under lock and key by mandate of our government for our own good!
    • jkflow
      • Aug 2021
      • 329
      Any car paint will work.
      Not sure where you are, all in the open here but minimum age verification required and that is a good thing imho.
      • JohnZ
        • 267
        I've got cans of Rustoleum white from previous projects. Where I live paint is not locked away nor do you need ID. Sounds like a lot of tagging going on.
          • 4340
          That's exactly why you can't buy it within city limits here in Chicago. It doesn't stop it, but it curbs it for sure.
          • JohnZ
            • 267
            Not to change the subject but I had a couple cans of Krylon Camo Olive that quit spraying for some reason. Was going to use it on a WW I plane but they wouldn't spray so I contacted Krylon Paint and gave them all the pertinent information about the two cans....they are going to send me two new cans of Camo Olive when available.
            How's that for service.
