making flex shafts
  • dbgryche
    • Sep 2021
    • 20
    making flex shafts
    Seeing how the shafts i need are all on back order i bought materials to fab my own but lack the expertise to make one and could use a little input. like how to get a clean cut of the first layer of windings off the cable for inserting into prop shaft and then the braising method
  • Jonathan DeMaria
    • Jun 2020
    • 114
    I use a small pair of flush cuts to unwind each strand & cut it about a inch or so down. Then i take my dremell tool with a cut off wheel to clean it up. I use 56% silver solder and the Harris white brazing flux. Good luck trying to find a video on the process, I know of one and it sucks. What flux and silver solder are you going to be using??
    • Jonathan DeMaria
      • Jun 2020
      • 114
      Start watching a bunch of different videos on YouTube about brazing. Im a plumber by trade so it came to me pretty eazy. There is definitely a little learning curve though. I think the hardest part is getting it brazed without deforming the flexcable and the alignment of cable and shaft. It has to be perfect.
      • larryrose11
        • Jun 2010
        • 768
        I believe Jeff Wholt may have what you are lookinh for.
        His work is great, and they are super strong.
        • Jonathan DeMaria
          • Jun 2020
          • 114
          If this all seems a bit mutch for you Im shure mcopracing,speedmaster, wholt racing as mentioned above, or aeromarine racing has them,you would just need to cut to desired length. Common lengths are 18"-24"
          • dbgryche
            • Sep 2021
            • 20
            well ill use your recommendation seeing how im learning... lol
            • dbgryche
              • Sep 2021
              • 20
              do you have links to mcop and speedmaster?
              • Jonathan DeMaria
                • Jun 2020
                • 114
                Mcopracing.com rossisales speedmaster. Just google them
