Water Cooling... Dual or Quad exit for Dual Motor Setup?
  • jaike5
    • 564
    in the spring nothing over 75* batteries 110*, water temp40*F . in the summer with water surface temp at 80* motor 105* esc 100* batteries 115*. prop 1814 p limited sport hydro.
    • jaike5
      • 564
      Let's see if you can wrap your head around this one!! The boat is a lizzard P limited mono . I put two lines into the motor with two lines out. two to the esc.
      wire drive, m447. Here in Ontario you can see 15 feet down , in Atlanta I can see 6 inch's down. so a lot of sediment. May have to prop down.But I have to keep up with Amp Daddy! That off shore course is long, with a cooler way the hell out there for an offshore bouy.
      • MidKnight
        • Aug 2021
        • 29
        Would there be any benefit of using 4 outlets instead of 2?
        • jaike5
          • 564
          The more water passing through the more heat removed.
          J.
