Ml Boat works 1/6 dual build thread, Newton 164 and 172.
  • jingalls007
    • 1015
    The 164 will sport the 95? Bud T-4 livery while the 172 with sport the T-6 2011 Valken.com livery. Both will run 10-12s motors, speed master hardware, Randy Rap turnfins, and ztw controllers.
    I?m currently working on the T6. So we?ll start there.
    Pics coming soon. It?s late and I?m falling asleep.
  • nocebo
    • Jun 2020
    • 79
    Looking forward to seeing the build!
    • jingalls007
      • 1015
      0E90C928-34AB-49F2-8AEC-0CDCD881AA2C.jpg4B9B4D22-32C3-4547-BB86-D5DABF319AB1.jpgFC400B82-3A6F-423C-9EAB-50925F64659A.jpg18CE02C8-6994-47EB-8B64-6F98F73766B2.jpg
      My phone screw up the pic configurations. I’ll have to fix them on my laptop. For now we have sideways pics.
      • jingalls007
        • 1015
        This will be the finished project, hopefully.
        • nocebo
          • Jun 2020
          • 79
          Looks great - you were not joking about the gas scale builds being enormous - cat for scale.
          Out of curiosity, do you fiberglass or CF the inside of your hulls?
          W
          • jingalls007
            • 1015
            W
            I do both. I tape the seems w/2” fiberglass tape and heavy, 12k cf down the middle.
            • jingalls007
              • 1015
              Made some progress on the vertices. Sandwiched the two halves, added wood and carbon fiber, then epoxied and sanded to prep for 2k black epoxy primer. Paint is HOK Black Sparkle Pearl, clear is spray Max 2k.
              93C659A5-832B-4869-AFCC-3194FDF69E04.jpgE5544247-36E6-4934-BD2E-5A850FC73E13.jpgA8E57E32-0292-49A9-839A-95C54F40338A.jpg
              I’ll finish the canard and horizontal tomorrow in the same way then onto the massive cowling.
              Note: 2k epoxy primer is really easy to work with. Sandeable in 30 minutes. Overcoatable in 20-30. There no need for sanding or waiting if you intend to go straight to your basecoat.
              My process was; prime, wait 30 minutes, sand, icing for small holes, then light primer, wait 30 mins, lightly sand with 320, clean with windex then straight to paint. Paint flash off is about 15-20 I 2k cleared all within a 2 hour window and the paint came out flawless; no wrinkles, no offgas
              Concerns from urethane basecoat. This is by far the best method I’ve used for rattle can paint.
              • Twood69
                • Aug 2018
                • 15
                Good luck on the builds. My Ml 172 is running great. Tp power 5870/750 kv on 10 cells with a swordfish 300x. 4 roaring top 5100 for batteries. 45143DD0-510D-4108-A39B-2B39F7A77701.jpg
                • jingalls007
                  • 1015
                  Originally posted by Twood69 View Post
                  Good luck on the builds. My Ml 172 is running great. Tp power 5870/750 kv on 10 cells with a swordfish 300x. 4 roaring top 5100 for batteries. [ATTACH=CONFIG]172766[/ATTACH]
                  Hey Tom, yes, your T6 inspired this build! Thanks for sharing again.
                  • jingalls007
                    • 1015
                    Some progress. CF and FG layup, side skins attached, bottom pan taking shape, upright mounts glued in.
                    4F9A2DAB-4734-481A-A2CB-65D2D14BD376.jpgE8A6D6C6-8183-49DC-977A-EED379980559.jpg97E926E4-87E0-448D-93E3-F977200CC981.jpg9D619770-E8BD-48F1-9F6D-54CEE1801C32.jpg
                    • jingalls007
                      • 1015
                      Tom I meant to ask did you install the rear shoes? My kit didn’t come with them included so I wasn’t sure if I needed to make them as they’re included in Mike’s mugshot pics.
                      • nocebo
                        • Jun 2020
                        • 79
                        Great progress, you are a much faster builder than me!
                        Im assuming the piece of aluminum is to support the turn fin?
                        • meangenesracing
                          • 1168
                          [ATTACH=CONFIG]172773[/ATTACH][ATTACH=CONFIG]172774[/ATTACH][ATTACH=CONFIG]172775[/ATTACH][ATTACH=CONFIG]172776[/ATTACH]
                          007, is that aluminum plate I see epoxied in? Looks to be in the wrong place
                          • Twood69
                            • Aug 2018
                            • 15
                            Yes. I made them from pictures as close to scale as I could tell. 1238F930-9113-48C1-965E-5FB77FBFD55A.jpg
                            • Twood69
                              • Aug 2018
                              • 15
