m34 raider
  • a53hoop
    • Oct 2019
    • 70
    m34 raider
    this is my first mono build m34 raider using a speedmaster stinger.should the hole for stuffing tube be as low on the transom as possible with stinger parallel with bottom of boat?? tks AL
  • Jesse J
    scale FE enthusiast
    • 7818
    Hi Al, welcome to the wonderful world of building.
    For anyone to provide helpful input, we need to know what your planned set up will be.
    In general the strut depth depends on several things:
    How much lift is built into the hull,
    Prop size, typically smaller with higher rpm systems
    Typical water conditions
    Speed / driving style (drag racing, oval racing or fun running)
    Mine is set up for oval racing, moderate rpm, 50mm prop and I have mine 15mm (keel to shaft center).
    I also did a wet well which allows me 1cm up down adjustment (with or without angle change) in addition to angle changes with no depth change. This is not mandatory, but since I did not know how much lift was built into the hull, I wanted flexibility.
    Share some details and we can help you get the performance you are after.
    Happy building!
    "Look good doin' it"
    See the fleet
    • a53hoop
      • Oct 2019
      • 70
      thanks for the reply .just looking for a nice sport running boats. also by myself here with no boaters i can find. running a 3660 1700kv 4s 4000mh batteries with speedmaster stinger and 4416d cnc prop. this is a similar set up ose sells. tks AL
