Df 53 Annihilator setup Q's
  • Rich
    • 581
    Hi, I was wonder if anyone can tell me a setup that will push the df 53 to 60mph? I need the works motor, ESC, Drive, prop etc. Any info be much appreciated. I'm just trying to get an idea of how much it would cost.
    Thanks,
    Rich
    24 R/C vehicles and still counting...What budget?
  • Peter A
    • 1622
    56mm can motor 500-650kv motor, 300A esc, 10s (2P?), 1/4" drive, 65-67mm props. I would recommend building with a flood tube and strut instead of stinger to dial in the hull better.
    • Rich
      • 581
      Any recommendations on a servo and rudder? Also how to you drill the holes for the rail motor mount?
      • photohoward1
        • 1781
        Why are you calling it a Q?
        Are you racing it in that class?
        • Rich
          • 581
          Sorry the Q stands for questions.
          • Rich
            • 581
            Is there nobody that can tell me how to drill the holes in the rails?
            • bogieboy
              • Jun 2018
              • 219
              the easiest way to drill holes in rails in the boat is with a short bit set, and a right angle drill head.
              • Rich
                • 581
                Thanks bogieboy! I thought that might be the best way. Anybody else got any info on rudder, servo and struts for this boat?
                • jaike5
                  • 564
                  I use a 1/4 scale servo, and a welding rod for a push rod to the rudder. Delta force sniper, 44”
                  Cheers, Jay.
                  • Rich
                    • 581
                    Sounds good, I was thinking about a tp 5670 600kv on 10s2p with a ztw 300 amp esc. I have heard that this esc motor combo has had problems, any thoughts?
                    • jaike5
                      • 564
                      lehner 3080/7T, sch 40160.
                      • Rich
                        • 581
                        That's an expensive motor! What is the sch40160? I cant find it on the net
                        • jaike5
                          • 564
                          shultz 40/160 or the 300 IMO are the best esc's. unfortunately that company shut down years ago. they sell for 7-800 U.S. dollars. They are deal when you can get one when they come up for sale every now and then . MGM is 1200.00 which is the closest you can get to sch. and they rarely work, have to bring a lap top to the pond to reprogram...... B.S. Sch.... plug and play.
                          Big boats are pricy 2-3K plus. You get what you pay for or less! Don't cheap out or you will be frustrated and end up paying way more in the long run.
                          J.
                          • Rich
                            • 581
                            Thanks for the tips. I think this boat is going to be out my price range for what it does. Not sure I'm going to build this one. Thanks for the help guys!
                            • bogieboy
                              • Jun 2018
                              • 219
                              in all honesty, this size boat would be cheaper to build as a gas engined boat.... stock zenoah 260pum would be about $200, add another $100 or so for a tuned pipe setup, then 1/4" drive line and a fuel container (most racers run IV bags)
                              i speak form experience, as i got an old Dumas DV60 for cheap, looked into powering it, and the outlay for motor, esc and batteries was astronomical.... i built it up first with a weedwacker motor, then had an opportunity to trade some chainsaw parts for an older (new in box) Hanson pro ported G230pum, got a pipe for it, and its a blast, not entirely tuned in just yet, but time has been slim to tune... rides good, but need to play with pipe length yet.... i think i am into the entire build for under $500...
