Raider m34 CF Equipment installed Need battery pick
  • Panther6834
    • Apr 2020
    • 708
    Originally posted by HTVboats View Post
    For your 34 Raider use a pair of 3300 or 3700 6S in parallel and you will attain your speed goals easily. A simple M545 or 1815-1817 ABC works well.
    Mic
    No can do...P-Limited is 4S. As for battery brands, I'm going to check out those Roaring Top and Giant Power packs. Thank you.
    In regards to your prop "recommendation", how can you suggest a prop without knowing what motor is installed? In the same boat, 1650kV motor will require an entirely different prop than, say, a 2050kV, or a 2300kV.
    ~ More peace, love, laughter & kindness would make the world a MUCH better place [emoji1690]
    • eric113
      • Sep 2011
      • 327
      Gaint power no longer sells lipos
      • Panther6834
        • Apr 2020
        • 708
        Well, that sucks...but, thanks for that info, nonetheless. Saves me from a never-ending search...lol
        • jim82
          • Jan 2013
          • 1358
          Dinogy are the same lipo
          • HTVboats
            • Jun 2011
            • 936
            Sorry I got the conflated with the 40X74 that was considering running on 6S and not P/L. Those props are for the 1600 motor on 6S. Two different Raider's here. For P/L I like a pair of 4S 3000-3300's in parallel. More ma than needed but you make gains in the final laps and don't stress batteries. Prop depends on motor.
            Mic
            Mic Halbrehder
            IMPBA 8656
            NAMBA 1414
            • Panther6834
              • Apr 2020
              • 708
              Mic
              https://www.roaringtopusa.com/70c
              No worries...I'm used to being confused. Happens to me all the time. In regards to the motor going into my P-Limited Raider, it'll be a 2030kV. Prop suggestions/recommendations?
              • HTVboats
                • Jun 2011
                • 936
                In our 29" P/Lims with 2050 motors we have run cut down Octura 642 & M445 to 43mm. 443's, 442/3 CNC alum., ABC 1714 1715 and 643/3 Dr Props. Just see what the boat likes. If I had to take one for all around conditions I like the CNC 442/3 blades. Inexpensive, balanced out of the box with machine matched blades.
                Mic
                Mic Halbrehder
                IMPBA 8656
                NAMBA 1414
                • Panther6834
                  • Apr 2020
                  • 708
                  Originally posted by Panther6834 View Post
                  I'm also looking for batteries for my Raider M34...personally, I'd avoid the Dinogy packs, as the C-rating appears to be highly overstated (65C rating, 38C actual).
                  I'll stick with the SMC & Gens Ace I've been running for years in my off-road racing vehicles, and the SMC & HRB packs I've been running in my boats.
                  for my Raider M34 (P-Limited), and the ProMarine Skater X2 P-Open), that's why I'm looking for something better...something TRULY race-worthy. Unfortunately, until this "worldwide lockdown" ends, and races start up again, it's near impossible to talk with anyone in-person, to find out what they're using.
                  Let me start off my issuing an open, public, and honest apology. Not being one to "give up", even though I said I wouldn't consider the Dinogy batteries, I did actually continue research into them...and, the more I researched, the more I found out that they were better than I had initially believed. I had based my 'thoughts' from the first two reviews I had read...and, even then, I hadn't actually read them word-for-word.
                  I was also won't about not being able to talk to anyone...there was Mark, the owner/founder of Dinogy. So, I called him up, and we talked for a while...QUITE a while, in fact (over a half hour)...and, by the time we hung up, 12 batteries were ordered - 4 each of 3 different types/capacities.
                  I'll be honest...I'm going to put them against my others, and see how they truly do. If they aren't as good, back to the others I'll go. On the other hand, if they're at least as good...and, to be completely honest, I'm now fairlyy confident they'll actually be better...Mark can expect additional purchases from me, and others (I can be good about "spreading the word") in the future. Whether, or not, you realize you 'elbowed' me, "thank you" to those who did.
