MHZ Racemaster build...
  • BrickBait
    • Jan 2019
    • 50
    Hello guys.
    Just returned from a small trip to a guy with waaaay to many boats in his workshop..
    Well, i wanted to buy some small parts and stuff as he is clearing out to make room for more and i ended up throwing a MHZ Racemaster C-AFK hull in the back of the car + the other stuff i first went to pick up.
    Now im roaming around the big interweb in search of hardware for this puppy... Im thinking a single prop setup, with a inline rudder.
    Electronics might end up at a Leopard or ThunderPower motor and Swordfish ESC.
    What hardware should i go for on a hull like this?
    Size, brands and so on...
    Its a little out side my normale size of boats, so i am a bit green here
    Cheers - Frank
  • PowerDemon
    • 353
    For electronics the Swordfish is an excellent choice. For the motor I would consider either Leopard or Neu. The TP motors are good too.
    I would use Speedmaster hardware. If I were you I would consider going with an offset rudder but if you are dead set on the inline setup I think Speedmaster offers an inline setup as well. This is what I would use for the rudder. That should be the right size for your build. Then you?ll need to pick out your strut (I would also go Speedmaster for this), trim tabs, and turn fins. Everything you need is sold here on the OSE site. Hope this helps!
    37" Fightercat Shocker powered by Neu 1530 on 10S
    • BrickBait
      • Jan 2019
      • 50
      Regarding offset Vs inline, i have been looking into that. But i cant seem to get a clear picture of the pros and cons. Some say one thing, and others state the opposite..
      I do get that offset is the way to go for oval racing. But as i wont be doing any racing, but purely Pond fly-by's, that will not have any influence :)
      Some say inline makes the boat unstable. Others state it made the boat more stable going from offset to inline. So im a bit out in the woods here.
      Those Speedmaster parts look good.
      As i am Europe, MHZ/MTC, TFL and Werner hardware is a bit easyer to get. But i am looking into Speedmaster also :)
      The Rudder you are refering to, is also a inline type as far as i can see. Looks good.
      Cheers - Frank
      • PowerDemon
        • 353
        The offset rudder usually gets better cooling water flow, you can go faster, they track in a straight line better, and it turns better. The only con is having to drill a few more holes in your transom.
        I've had the chance to see some MTC hardware in person before and I can say they make some stunningly good looking hardware. So if you have the cash that would be my first choice. My cat has TFL hardware on it, and it works well with no problems but it is nowhere near as nice looking as the MTC stuff. MTC appears to make a real nice looking inline setup. I have heard good things about Werner as well.
        • Alfa Spirit
          • 2183
          TFL Hobby hardware, trim tabs are RC Boat Blitz, Flex shafts are OSE:
          With one BL motor setup, prefer center rudder with more weight on the left side:
          • Jesse J
            scale FE enthusiast
            • 7818
            I have a racemaster on its way to my garage, so maybe we can trade notes.
            I am toying with twin tfl outdrives...
            "Look good doin' it"
            See the fleet
            • Jesse J
              scale FE enthusiast
              • 7818
              Anybody know what 1:1 hull this most resembles?
              Doesn’t look like outerlimits, definitely not fountain... anyone?
              See the fleet
              • Jesse J
                scale FE enthusiast
                • 7818
                twinsies?
                this is where I'm thinking of heading with this hull:
                See the fleet
                • Jesse J
                  scale FE enthusiast
                  • 7818
                  Got parts... now for surgery!
                  Counter rotating props (38mm) will probably need to be cut down to the 35mm stock size. Maybe not if run on 3s per motor.
                  Here’s mock up of transom.
                  See the fleet
                  • Jesse J
                    scale FE enthusiast
                    • 7818
                    Hope this is some inspiration Frank, while you wait for parts.
                    See the fleet
                      • 4338
                      Very cool
                      • Jesse J
                        scale FE enthusiast
                        • 7818
                        Post op recovery
                        Here she is as of 10 min ago:
                        See the fleet
                        • jfrabat
                          • Apr 2020
                          • 110
                          That is one sweet looking boat you got there, Jesse! I love the looks of those TFL outdrives! I cant wait to try mine! Are you gonna run them on 3S or 4S this time?
                          • Alfa Spirit
                            • 2183
                            Beautiful, red TFL outdrives and red RC Boat Blitz trim tabs are perfect.
                            What motors do you use and what is the maximum RPM for the TFL outdrives ?
                            • Jesse J
                              scale FE enthusiast
                              • 7818
                              My experience with these drives and desire for scale rather than gps speed makes me NOT want to change the motor nor prop diameter (although I may look for a pair of comparable red motors). These SSS motors are smallish 2200 kv motors of marginal quality, so I’ll try on 3s and maybe 4, depending on handling.
                              The Stock normal rotation props are 35mm and to fit the 4mm shafts and counter rotating pair limitations, I had to go with 38mm. I will be sharpening and possibly trimming them down. I have a pair of 3blade 36mm... but for 1/8” shaft size.
                              Anybody know where I can get a pair of 36mm counter rotating 4mm props? (That’s not in a super long shipping delay country.)
                              See the fleet
