6s Rico 31"
  • sampit
    • Jul 2009
    • 466
    6s Rico 31"
    Can any recomend a set up for a Rico 31' mono
    Would like to use my TP4050 1450kv motor
    I'm thinking 6s may be 7s but I'm not sure what size prop would work and my ESC is only 120A but I think on 6s it would be ok but any help aprecated.
    FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
    Popeye Hydro T600 1400kv 6s1p
    That’s a pretty big motor for a 31” mono. The ESC is pretty small for it, but prop management can help. Start small, with an x445, that should get you into the 50s with the right battery and trim. Depending on the ESC you may not be able to exceed 6S.
    • sampit
      • Jul 2009
      • 466
      Thanks Fluid
      Yes my ESC is 2s to 8s capable.
      So can go 7 or 8s but will that be to much RPM
      Would I be right saying that it would pull around 80A on the 6s setup using the X445
