"Old Wood" 3.5 Tunnel Restoration and FE Conversion
  • Darin Jordan
    • 9446
    Had this "Old Wooden" 3.5 Tunnel sitting around for some time, and I've purged most of my other projects, so I figured I could tinker on this a bit over the coming months to hopefully make it useful again.
    Not even sure what it is, but whoever built it did so with a LOT of skill and care. Pretty nice lines, well made, etc.
    First step was to sand... and sand... and sand... sand some more... and I still have a little sanding to do.
    Going to do some structural upgrades, and then update the layout to support an FE setup. Not for racing, just for fun. It's a TINY boat... 24", so I'm going to set it up for a high-revving 2S setup, which will allow the use of appropriately smaller props and will also keep it light.
    Small_OPC_001.jpg Small_OPC_003.jpg Small_OPC_004.jpg Small_OPC_007.jpg Small_OPC_012.jpg
    Darin E. Jordan - Renton, WA
  • Darin Jordan
    • 9446
    And more sanding...
    Small_OPC_010.jpg Small_OPC_013.jpg Small_OPC_014.jpg Small_OPC_005.jpg Small_OPC_006.jpg
    • Darin Jordan
      • 9446
      Took a break from the sanding to do some machining on the K&B 3.5 Lower for the FE conversion...
      K_n_B_Lower_FE_001.jpg K_n_B_Lower_FE_002.jpg K_n_B_Lower_FE_003.jpg K_n_B_Lower_FE_004.jpg K_n_B_Lower_FE_005.jpg
      • Darin Jordan
        • 9446
        3.5 Mods continued...
        K_n_B_Lower_FE_006.jpg K_n_B_Lower_FE_007.jpg K_n_B_Lower_FE_008.jpg K_n_B_Lower_FE_010.jpg K_n_B_Lower_FE_009.jpg
        • Darin Jordan
          • 9446
          Teflon in these is draggy... so I'm replacing it with a brass stuffing tube, like I do in all my lowers. Propshaft will be replaced with a HyperformanceRC 3.5 unit, which has a longer propeller shaft and is supported by better bearing surfaces.
          Starting to add in the bulkheads and other structural mods to support the FE Conversion...
          • Shooter
            Team Mojo
            • Jun 2009
            • 2751
            At first glance I thought it was a hotshot, but after a few more pictures......WHAAAA? WHAT IS THAT?? Awesome mods on the 3.5!
            • 30nitro
              • Feb 2018
              • 330
              Very cool .....I'm resurrecting and old Dumas 36 inch Dragon Fly shovel nose hydro......nitro inboard to FE.....rare hull I'm told...very well built and stored..never been wet.... Should be interesting......
              • Darin Jordan
                • 9446
                Couldn't help myself. No sense in doing this if it's not going to look good!
                Polished up the now modified K&B 3.5 lower...
                  Great job Darin! Leg looks Uber cool
                  • RaceMechaniX
                    • 3024
                    Darin, that's the tunnel I gave you years ago right?
                    Tyler Garrard
                    NAMBA 639/IMPBA 20525
                    T-Hydro @ 142.94mph former WR
                    • Darin Jordan
                      • 9446
                      It is! Figured it was time to make it look like it belongs on my shelf. :)
                      • RandyatBBY
                        • 3943
                        After I get my shop set back up I hope to redo some old projects, looks like you are having fun. I am having a problem finding most little things in my garage, they are in a box some where. LOL
                        Randy
                        BBY Racing
                          • 4338
                          looking good
