Black Pearl II Hydro - 2020
  • TRUCKPULL
    • 3293
    #91
    Pete
    What is the max battery height at the 165mm length on the front.
    Larry
    • Shooter
      Team Mojo
      • Jun 2009
      • 2751
      #92
      Hi Larry. Looks like 32mm. You could always shave some material off the motor mount gussets to give yourself a little more length. What batteries are you trying to fit?
      I'm going to seal it tonight. I've been using an old T-shirt to work it into the wood. Sounds ridiculous, but it's the best method I've found so far. Excellent results.
      • Shooter
        Team Mojo
        • Jun 2009
        • 2751
        #93
        Also, forgot to mention. I cut the top cross member of the bulkhead. I do this with all my boats. I sanded down the lower cross member as well.
        • TRUCKPULL
          • 3293
          #94
          Pete - the 165mm length, is that to the motor mount gussets at the floor??
          Larry
          • Shooter
            Team Mojo
            • Jun 2009
            • 2751
            #95
            Yes Larry, exactly. Keep in mind that the height drastically increases as well as you move back.
            • Shooter
              Team Mojo
              • Jun 2009
              • 2751
              #96
              A little more work on the P boat. I sealed the it with West using a small cotton rag. Rubbed it in. Starting to mount hardware and bend the stuffing tube. Hopefully I'll be priming both boats by the end of the week.
              • Shooter
                Team Mojo
                • Jun 2009
                • 2751
                #97
                I glassed in the stuffing tube. Many schools of thought on the bend. I typically go straight from the motor shaft and then a gradual "J" bend to the strut.
                • Mike W
                  • May 2018
                  • 348
                  #98
                  Love these wood build threads. My BP17 is still in the box. I wonder if there could be a way to seal the wood before laser cutting it? It sure would be nice to only have to worry about the edges being sealed when building a wood boat. I'm surprised the ply manufacturer's don't offer such a product. The premium in cost would be worth it IMO and surely it would result in a lighter boat if it was some sort of adhesive film applied under pressure with heat. Something almost like magic transparent scotch tape.
                  Otto RC Marine
                  • Shooter
                    Team Mojo
                    • Jun 2009
                    • 2751
                    #99
                    Hey Mike. Not a bad idea. I've considered sealing parts before assembling for sure, and think I'll try it next build. I suppose we could rub it into the wood before laser cutting, but I'm not sure if the fumes would be hazardous or not.
                    • ezhitz
                      • Aug 2009
                      • 466
                      #100
                      EAEE1DF4-4F24-4060-BACB-ACD47699CECF.jpgHey Shooter I noticed you cut out the former top brace I there is no problem with strength when doing that. I assume this means you will run your batteries length wise. I think I will do the same seams like it will make setup easier.
                      :canada
                      • Shooter
                        Team Mojo
                        • Jun 2009
                        • 2751
                        #101
                        Hi, your boat looks nice! Yes, I remove that upper brace on all my builds, and I do run my batts and esc lengthwise. That being said, I glass every seam and joint on the boat for srength. I also think the curved hatch stiffens up the boat more than people think, and acts like a top cross brace.
                        • ezhitz
                          • Aug 2009
                          • 466
                          #102
                          Thanks, I will remove mine to as I also glass all the seams.
                          :canada
                          • T.S.Davis
                            • 6266
                            #103
                            On the full sized Pearl I always keep that top brace. One the smaller I broke it off. I'm not that concerned with the lower power and weight.
                            Noisy person
                            • Namba328
                              Factory Team Pilot SPP
                              • Jul 2011
                              • 1229
                              #104
                              Hey Shooter. There's a guy on Facebook looking for a nose cone for the ul1. Would yours work for him? Here's his profile to contact him if you're on Facebook lol. https://www.facebook.com/brandon.groothouse
                              Tommy Levescy sponsored by: RCJuice.com, Rawspeed, Scorpion Precision Performance, TC Racing, Triton RC, Oxidean Marine and Cencal Hobbies.
                              Current Namba 1mile record holder: Pltd sport hydro 1:19:72 P-sport hydro 1:14:31
                              • Shooter
                                Team Mojo
                                • Jun 2009
                                • 2751
                                #105
                                Sorry, no the UL-1 is much smaller than the original Black Pearl nose cone that comes in the kit. They are not compatible.
