Black Pearl II Hydro - 2020
  • InspGadgt
    • Jul 2018
    • 174
    #496
    Question...since everyone seems to be running the Mojo turning fin...On mine there is no torsional angle adjustment on the bracket. There is only front to back adjustment on the fin itself. Is this normal for a curved turn fin? The curved turn fin on my UL-1 has torsional adjustment as well as front/back. Do you just set it to perpendicular to the ride plane? Thanks!
    • Shooter
      Team Mojo
      • Jun 2009
      • 2751
      #497
      I always run my turn fins completely neutral. No fore/aft tilt and perpendicular to afterplane. I know a lot of folks like to run a little aft tilt to hold the boat down, but it adds drag. Just my opinion.
      • Rookieboater
        • 131
        #498
        Originally posted by TRUCKPULL View Post
        First thing I see in your picture is;
        Turn the water jacket on the motor, so the output is at the top
        (highest point above the bottom of the boat) NOT the side.
        The way the water jacket is right now. The water in the jacket will never get above the output nipple.
        This is one of the main reasons that motors get over heated.
        Also you should use a longer jacket.
        Larry
        Larry,
        Doesnt the water only shootout the water exit when its under pressure? I sometimes have brain blockage so bear with me. But doesn't the jacket fill completely before water shoots out of it? Im sure I am missing something here. Please help.
        • CJPB32
          • Aug 2022
          • 72
          #499
          You'll trap an air bubble inside the jacket. Outlet on top lets the air purge.
            Pete, could you have made the bottom sheet a little smaller? LOL... Holly molly, that's a slim fit. Not much extra anywhere. YOu gotta get the bottom just right!
            Maybe add an extra 1/16" on he front end?
            • T.S.Davis
              • 6266
              #501
              I was pretty happy with he belly skin. I usually make the skins myself. I don't have those slots open on each side. I'm going to skin my sponson before I fill in those two slots. I can weasel clamps through there to clamp my ride pads. I'll post a pic when I do it.
              Noisy person
              • T.S.Davis
                • 6266
                #502
                I have two on the bench right now. I've built 4 boats since Christmas I think.
                Noisy person
                  Very cool, thank you Terry!
                    It's a great cut part and fits really nice. I just find there is not much wiggle front to back is all. After this one I still have one more to build and a JAE 33. I figure with what I learned building this first one that the next one should be a fair bit quicker. I need a few more clamps maybe. We will see shortly.
                    • T.S.Davis
                      • 6266
                      #505
                      I had two framed and sticked in under a week. Would have had both skinned in under 2 weeks but I gave myself lateral epicondylitis block sanding frames. Dough!
                      Noisy person
                        I'd stick to that story too if I had Tennis elbow...
                          [ATTACH=CONFIG]176572[/ATTACH]
                          Those small clamps juuuust barely fit in there and I had to trim the sticks a bit in mine. I wish I bought 2 larger clamps that you used there. I'm not liking how much tension the bottom sheet has when clamped up like that. It's not a wonder why the bottom sheet can tear off in a heavy stuff etc... What do you reinforce that area with to stop the batteries from dumping out into the lake??
                          I was going to try to pre-bend the sheet but I was concerned that it would get all wavvy and loose it's flatness and profile.
                          Cough up some more of your secret Davis, lol...
                          I'm trying to muster up the courage to glue this part up. My clamps are quite large and heavy so I need to use 10lbs counter weight. My clamps are also use old borrowed and not the same Dewalt quality like the little buggers I just bought.
                          • T.S.Davis
                            • 6266
                            #508
                            I sheet the battery tray with G10. I've used just another layer of wood before too. I also add sticks to the front bulkhead on the inboard side to give the belly skin more too grab on to.
                            Noisy person
                            • Ryanj
                              • May 2020
                              • 133
                              #509
                              Reinforcing the bottom sheet especially up front where the battery’s went. I used 5k carbon fiber and Inlayed the bottom to increase the floor strength and i can Velcro my lipo's to the floor on my LSH V12 pearl . Just another idea to what I did. AD81115A-1E53-49BB-B272-499D4FEBD8FE.jpg
                              • T.S.Davis
                                • 6266
                                #510
                                I try not to remove that cross support on any of my Pearls. We pull about 3G in the turns at 60 mph. A large percentage of that weight hangs from the turn fin. The fin is attached to the bulkhead with that cross support. I try to keep it if I can make it work.
                                Noisy person
