Black Pearl II Hydro - 2020
  • T.S.Davis
    • 6266
    #286
    Originally posted by eric113 View Post
    Quit being scared to try out some plastic sheeting.
    Not quite a fear exactly. Is it?......I guess I am skeerd.
    I scratch built a vacuum forming machine coined by my wife as "Terry's Easy Bake Oven". I used to make hulls from ABS and polystyrene. Sold a few. Nothing crazy. Even pulled one out of clear PETG. Crazy looking thing. You could see all the innards. Ran fer crap. The toughest of the bunch is ABS but it's a pain in butt to form. You have to dehydrate that to heat it or it blisters. Ugh. Hated it. Might work as a skin. ABS is pretty solid until you heat it up. Works well for injection mold too.
    Once we all went brushless, lipo, and crested 50mph I stopped making them. If they stuff at speed they tended to come apart. Sometimes the plastic ripped but usually the seems gave out. There's just no way to make rock solid seem up in the front of the hulls. It could well have been that the flexibility of the styrene made the joints eventually fail. Couple that uncertainty to the sheer dollars involved in the internals now......I just gave up on them. Still have the machine though....cuz I'm hoarder....apparently.
    I'll snap a pic of the bottoms on these latest builds later tonight. I skinned the bottoms with G10. That's plastic.....sorta. Fiber reinforced plastic but still plastic. It's much heavier than simple ply with resin but it's also a ton stronger. Worth it? Meh. Probably not but I feel good so screw it. I also worried that the bond between the wood frames and the G10 is purely mechanical in that the resin doesn't actually soak across the joint and make the frame and the skin a single matrix. That really is a thing and adds strength to the joint. The first one I did with the G10 this way was my sons and he's hit everything but the neighbors cat with it. He's also difficult to beat with it. Not sure if its the boat or his skill. So far so good though. Boat hasn't exploded.
    Noisy person
    • Shooter
      Team Mojo
      • Jun 2009
      • 2751
      #287
      For me it's always been the seams, as Terry said. The only guy that figured it out was Phil Pace. The vacu-pickle was indestructible. Great boat.
      • T.S.Davis
        • 6266
        #288
        Plastic belly. Wire management is solid on this one.
        P Pearl 4-28-22.jpg .
        Noisy person
        • eric113
          • Sep 2011
          • 327
          #289
          [ATTACH=CONFIG]174877[/ATTACH] .
          P limited I assume? Since your using mamba X. I really want try one for my p limited.
          • Shooter
            Team Mojo
            • Jun 2009
            • 2751
            #290
            What wires? Man, that's tight! Nice!
            • T.S.Davis
              • 6266
              #291
              Yep. Limited. I run the tiny Castle for spite. Some like to imply that I use amps to go fast. Impossible that I might have figured something out after 20 some years. I think the next size up from this is a better option. The 8s would fit in there and be nearly bullet proof.
              My son got me started trying to keep everything out of site. He reworks the leads on the servos in his cars so that they're just an inch or two. ESC with maybe a 1" lead looks weird but no crazy coil of wire to hide.
              Noisy person
              • RandyatBBY
                • 3943
                #292
                Hi Guys
                I read most of the thread and could not find the Spruce info, Got a link?
                I found bigger but not 1/8 and how many lengths will I need?
                Randy
                BBY Racing
                • longballlumber
                  • 3417
                  #293
                  Silver can P-limited motor?
                  • ezhitz
                    • Aug 2009
                    • 466
                    #294
                    I thought the same maybe he shaved off the blue save more weight.
                    :canada
                    • jaike5
                      • 564
                      #295
                      Nooooo , its platinum!!
                      J.
                      • Shooter
                        Team Mojo
                        • Jun 2009
                        • 2751
                        #296
                        Hi Guys
                        Hi Randy. I sent you an email. Let me know if you are still having trouble finding spruce sticks. Thanks.
                        • Shooter
                          Team Mojo
                          • Jun 2009
                          • 2751
                          #297
                          Finally getting another coat of primer on this thing. Amazing how much goes into prepping for one coat of paint. All the taping, cleaning, mixing, and of course acclimating everything to the ambient temp for a few hours prior to shooting paint. (we are in the middle of a heat wave here in Michigan). Did klasskote prices go up? I can't remember paying this much for paint! Eeeeek!
                          • TRUCKPULL
                            • 3293
                            #298
                            Pete
                            I sent you an E-Mail
                            Larry
                            • RandyatBBY
                              • 3943
                              #299
                              I found them on ebay, thanks
                              Randy
                              BBY Racing
                              • T.S.Davis
                                • 6266
                                #300
                                You guys keep spelling mahogany sticks wrong.
                                Noisy person
