55" C1 Cat twin FE build
  • AlterEgo
    • Sep 2019
    • 3
    I bought a 1.4m off shore cat hull that came with a 26cc gas engine. I have decided after cracking 2 oem pipes at the bend and a 3rd pipe leaking water on the o-rings i cant seem to stop, mixed with the odd stall, messy fuel oil inside of boat, car stinking off fuel, mixing fuel, dangerous idle without a clutch and the noise annoying people where i like to run it, ive had enough and started my FR conversion. As i still a noob any advice would be apprecited.
    Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.
    Make sure you clean the oil and gas from within the hull, I?ve used Simple Green for this.
    I have a pal whom did the King of Shaves with twin TP 4060?s
    • AlterEgo
      • Sep 2019
      • 3
      Thanks for the tip to remove the oil and gas, will do. I've gone 1/4" counter flex cables with 140mm outdrives to get the props to clear the rear overhang transom. motors are twin leopard 4074 1800kv , ill be running 6s with 2x 150amp ESC's. I hope to cut down some large (gas) 4 blade brass counter props ive bought cheap, otherwise will be hoping to drill out some 3/16 props.
      • AlterEgo
        • Sep 2019
        • 3
          You could go with some stepped down 1/4” cables then just run 3/16 props. https://www.offshoreelectrics.com/pr...ose-cable-1290 Just run 1/4” drive dog as opposed to 3/16”. This keeps the shaft from breaking at the step down
          I think we put some 648/2?s on my friends and it went well. 447?s would be a safe start but will likely run 450?s well. Try to stay with two blade props and do not try to drill out 3/16 ones, It is impossible to keep a straight line. 4 blade props will draw twice the amps
          Shawn
            Actually that is a reasonably HOT setup with 1800kv an 6s so be careful and check temperature often.
            • Alfa Spirit
              • 2183
              This is a big cat 1,40m. 2 x 8S with 1200kv motors is a minimum setup imho ... Did you buy motors and escs ?
