Delta Force 28 Pathfinder
  • HTVboats
    • 936
    Just an observation with the amps your pulling and low speeds I feel your probably running way too wet. Large controller and weight too forward, None of the props you mention give enough bow lift. My DF 28 runs 52 mph (83kph?) with a 3660 leopard 2050kv 4S and 1714ABC, 49 with a CNC 442/3. My 443/2 runs 45mph. Get more lift in a prop or move your motor and esc to the rear.
    Mic
    Mic Halbrehder
    IMPBA 8656
    NAMBA 1414
    • hughb
      • 152
      Thanks Mic that's some good points you make. I've got some new props coming to try, and I'll put the ESC back in the rear of the hull, where I initially was planning for. The motor position is too much effort to change. Oh and I measured the COG, it's currently at 39%.
      • Jesse J
        scale FE enthusiast
        • 7818
        Ugh, well moving a motor is some work, but imho definitely worth it. I’ve never had a boat that wanted more than 33% cog.
        "Look good doin' it"
        See the fleet
        • HTVboats
          • 936
          I think moving the ESC to the rear will be not too difficult. It also should let you know immediately if weight is an issue. Good work, keep testing and share your results to benefit everyone.
          Mic
          Mic Halbrehder
          IMPBA 8656
          NAMBA 1414
