Cutting a flex shaft?
  • jfrabat
    • Apr 2020
    • 110
    I have at least one of those mounts in a boat I own. I unscrewed the hose barbs and threaded in stainless grub screws to fill the holes just so I didn't have to look at the unused connections.
    Good idea. I will try to find some!
    On the water cooling jacket water exit should be on the hi side and directly on top
    Intake is on the low side. But I cannot get the exit directly on top because the motor mount is in the way. I just moved it as much to the top as possible, though.
    • dasboata
      • Dec 2010
      • 3972
      dremel the mount or get the fitting under the mount
      • Grimlock
        • Jun 2016
        • 2
        Just a question about cutting flex cables. Besides cutting them to fit your project, are there pros / cons to having a longer cable over a shorter one? Also, is there a minimum overall length you shouldnt cut shorter than?
