DF 29 build
  • alvinsmith75
    • 635
    DF 29 build
    Should I use rails in my build or will I be ok just epoxing everything to the bottom of the hull including this motor mount?
    http://www.offshoreelectrics.com/pro...ount_large.JPG
    Thanks, Alvin
    Setup will be Feigao 10xl, Fullers hardware, Hydra 120 w/external BEC, octura x447 prop, and Flightpower 4s1p lipo.
  • Jimmy Sterling
    • Apr 2008
    • 417
    If it was me, I'd definately put rails in. But whether they are really needed or not is argumentative,
    Come to the FASST side
    • mtgoat
      • Apr 2008
      • 103
      On my DF 26, I installed minimalist rails just to mount stuff onto. Before doing that, I layed in an extra layer of fiberglass on the bottom of the hull.
      • SLAUGHTER_AUS
        • Sep 2008
        • 52
        NICE, i just got one of these aswell... look forward to seeing it go.
        will try till smoke?
        www.slaughtermotorsport.com
        • Scott T
          • 625
          If it is an original DF29, you could probably mount directly to the floor. They're fairly thick. If it's a copy, I would use rails, or lay some carbon cloth in there for extra stiffness.
          My DF33 copy has a layer of carbon added, and everything mounted to the floor (same mount as you showed). It's more than strong enough, but was flimsy without the carbon.
          Scott Tapsall
          Pine Rivers Model Powerboat Club - Facebook Page
          My Gallery
            Good point. Fiberglass is pretty poor at adding stiffness, far better to lay in some carbon fiber or to epoxy in a pair of graphite kite booms. Either adds far more stiffness than a layer or two of glass cloth.
            • SLAUGHTER_AUS
              • Sep 2008
              • 52
              How is your red one coming along scott?
              • alvinsmith75
                • 635
                Ok went with rails and made my own motor mount to copy the mount in my Fullers DF33.
                What do yall think?
                I'll post completed pics later
                Alvin
                • kck741
                  • 282
                  mount looks good,but you might want to think about cutting it up a little to cut down on wieght mybe add some holes,to make a light wieght mount.nice custom work
                  S.S.R.C-Southern Style Radio Control
                  • alvinsmith75
                    • 635
                    I didn't weigh it but it is light, made of .064 aluminum.
                    • Jimmy Sterling
                      • Apr 2008
                      • 417
                      Weight will not be an issue as you are running 4s, if anything you will need to add a slight amount of weight.
                      Is the extra piece of timber and aluminium to mount your speed controller to ?
                      • ED66677
                        • 1300
                        Agree, I have a 29" copy and I've used the original plywood rail, a bit shortened!
                        Emmanuel
                        • alvinsmith75
                          • 635
                          Yes it is. I'll put pics later.
                          • tylerm
                            • 310
                            I've got the same boat as Ed, but had the manufacturer put in an extra layer of glass when he was laying the boat up.
                            I didn't use rails but if i did it again i think i would definitely put the rails in.
                            Tyler.
                            • Jimmy Sterling
                              • Apr 2008
                              • 417
                              Why not mount the speed controller to the mounting plate that bolts down ? - You'll save a little weight
