Warning: Undefined array key "scheme" in phar://.../vb/vb.phar/api/content/link.php on line 2
Warning: Undefined array key "host" in phar://.../vb/vb.phar/api/content/link.php on line 2
No they are 1/6 scale. I think the 46" vbox is considered a 1/4. But I would not be able to fit two of these in the hull, and if.. They would stick out to high..Tomorow I will take of the two black squares at the buttom. That will lower them half an inch. And I will see how I can make the lit so that the motors not just stand on top of it.
Each motor is 493 gram / a pound with the squares. And measures 10x10 cm
Det var sku da rart at se en dansker mere herinde...
Mvh Sven
Okay :)
Anyways, should look cool. Its a very wide lady you got there... :)
Im gonna follow your build.
Du er rent faktisk den første dansker jeg er stødt på her inde.
Lige bortset fra Kent fra CustomRCparts.
Han må vel betegnes som en dansker i eksil helt der nede Down Under :D
