velcro straps
  • Norwest
    • Mar 2014
    • 165
    velcro straps
    Ok, I want to seal inside a wooden boat. I want to put Velcro to hold lipos in place but if I seal the interior, will Velcro hold or do I have to epoxy or use the gray adhesive ( forgot name ) to hold straps in place. The boats are 22" and shallow type so lipos will lay in bottom and the rest of equipment will need to be also strapped in, thanks for your help!! This is a winter project and keeps cobwebs away! Also J&B weld is the name I forgot. Also could 3M spray glue hold on Velcro? Thanks!
  • Jesse J
    scale FE enthusiast
    • 7818
    Velcro will stick to epoxy or other sealant... until it gets wet or old.
    Are these high performance boats? If so, you can epoxy the loop side so that the buckle and flap are in the right spot.
    "Look good doin' it"
    See the fleet
    • Norwest
      • Mar 2014
      • 165
      Thank you!!!
