cutting 1/8" plywood in stead of lazer cutting- what can i use. Winter project.
  • Norwest
    • Mar 2014
    • 165
    Long title but might help with good replies. Project is making a Wild Thing during winter months, thanks for all replies! Have a good day!
  • NativePaul
    Greased Weasel
    • 2770
    Typically a fret saw or a scroll saw, but I think the wild thing is flat enough that you could probably use a hack saw or a band saw too.
    • Norwest
      • Mar 2014
      • 165
      Thank you!
      • pescador
        • 503
        I’ve used a jig saw with no problem to cut out parts roughly from a big sheet, then trim them with a scroll or bandsaw and then sand up to the lines. The best tool I’ve purchased is a Rigid oscillating sander if you plan on more builds it’s a time and elbow saver. :)
        Sent from my iPad using Tapatalk
        Namba District 16
        • 785boats
          Wet Track Racing
          • 3423
          I use a scroll saw for some of the tricky shapes. But a straight edge & a sharp knife for the straight lines work well. A palm plane & a sanding block are always useful too.
