Properchopper's VS-1 build
  • properchopper
    rcgoatbuild@snotmail.com
    • 6958
    Here's where I'm at so far :
    1] Notched transom to get pivot plate behind rear sponson tip ; using very cool adjustable Hyperformance mount.
    2] mount in place
    3] Hyperformance Angle Drive machined [carefully with drill press] to allow coupler to drop in
  • properchopper
    • 6958
    More pix :
    1] Motor in place. Used REK/ Fullers motor mount adaptor, Bolts right on !! Drilled adaptor mounting screw holes out from the top & countersunk the screw holes & they lined up perfectly with threaded holes in the Hyper mounting base [ square-end flex shaft had to be shortened slightly to get correct mating end-play]
    2] servo detail
    3] box mocked up.
    Awaiting rubber boots to arrive for pushrods & wires to pass through transom.
    • Grimracer
      • 656
      O man.. that angle drive has a ton of lift in it.. Be carefull with that setup.
      Keep us posted.
      Grim
      • Flying Scotsman
        Fast Electric Adict!
        • 5190
        Tony, push the envelope. Way to go. We await the results
        Douggie
        • properchopper
          • 6958
          I kind of figured it would after looking at the rather thick cross section of the lower unit & the way it curves up.[ A bit late, since I bought it sight unseen.] I'm striving to get the interior layout to allow some good rearward CG adjustment just in case. In all honesty I bought the angle drive 'cause of it's "cool" factor, but I do have the REK from my TS-2 to bolt on if the Hyper causes handling issues. Then again, if Santa's good to me a Lawless may just show up.
          • properchopper
            • 6958
            Douggie
            Thanks for the encouragement Douggie. I never could quite get my feet in step with conventional wisdom !
            • eboat
              • 693
              If the angle drive has lots of lift why is that bad ? it might help get it going
              If you look at the boat the center of the prop is level with the bottom of the sponsons and this is where the boat will do most of its running . There is not going to be very much of the leg in the water anyway when it gets up on plane
              • properchopper
                • 6958
                Bro, ever since this issue of lift was raised I've been stressing about it, but I've been looking at it and looking at it and have the same observation that you have.We'll see once its in the water. BTW, Dave at Hyperformance told me the other day that he has a new drive coming out in January. Maybe it'll be the "de-lifted" version, we'll see.
                • RandyatBBY
                  • 3915
                  Tony Hi
                  A little help use a set up board to pre set your out drive. Hear is mine below.
                  Now this is my finished setup for racing at kaiser cove.
                  Randy
                  BBY Racing
                  • properchopper
                    • 6958
                    Randy, I have the setup board from the TS-2. Thanks for the tip !
                    • Grimracer
                      • 656
                      How is the build going?
                      Grim
                      • properchopper
                        • 6958
                        more progress
                        Mike, thanks for your interest. Here's where I'm at so far : [I'll use two posts to spread out the images]
                        1] : The "pass through" tube farm ; { I.D. of motor wire tubes large enough to pass 5.5's in the event of a bigger power train in the future }
                        2] nipple farm
                        3] SC water lines
                        • properchopper
                          • 6958
                          Gettin' close !
                          More :
                          1] servo detail [ servo plate will be removeable to get under it ]
                          2] other servo view
                          3] motor/drive
                          4] SC can raise up to shift battery further aft for more rearward CG if necessary
                          Mock-up's pretty much done ; time to Z-Poxy everything & assemble/glue/seal.
                          Probably will lay a bead of 5200 to make watertight.
                          • Grimracer
                            • 656
                            Prop.. Looking darn good..
                            A few things to keep any eye on..
                            The skeg on that lower unit has a radii on the upper leading edge.. You need to get rid of that.. Also.. the skeg itsself will likey be to small for the boat.. Keep that in mind as you are testing the boat.
                            Grim
                            • properchopper
                              • 6958
                              Thanks, Mike. I have "plans" to do some blueprinting on the lower.
