ML Boatworks RSX380 Outrigger! My first FE wood kit build...
  • sammyha
    • Jul 2018
    • 1038
    #271
    Thanks hey for the feedback. Great insight on the dyhedral feature of Mike's design. I will take that bushing out and clean off the loctite...
    Sent from my SM-G950U1 using Tapatalk
    • sammyha
      • Jul 2018
      • 1038
      #272
      I have all my colors layed down. As far as what I'm painting and what stays natural.
      Next is canopy, turquoise pinstripes and lettering. The lettering will be done in turquoise and white.
      • sammyha
        • Jul 2018
        • 1038
        #273
        With this two part Klass Kote epoxy paint, it can be re-coated in 24 hours. But it takes 4 days to a week to fully cure.
        I've taped it for the next color in 24 hours without a problem.
        I'll probably let all this sit for awhile. Then I can handle it without concern for the rest of the painting.
          • 9438
          #274
          I want to thank you for this highly detailed build. My 310 is built but not rigged and finished.
          Paul helped me with my build, specially the sponsons. Hopefully they are paralel and straight. I will have to check them when back at apartment. I think mine are o.k. thanks to Paul.
          The KlassKote info was so welcomed since I have some stored away that I bought in 2014, hopefully it's still usable, you think? Since I don't have a compressor to spray, your brush technique is very welcomed!!! I will give it a try. If it works I can get some orange for my rig. I just have white now.
          Thank you so much. I will be reading it over a few more times.
          • sammyha
            • Jul 2018
            • 1038
            #275
            Your welcome. It's good to share experience and ideas, we all benefit when that happens. I learn so much this way too. Paul has also been a great help to me...
            I have a little bit of white K & B Super Poxy paint that I used for many years(wasn't enough left for this project and I had no other colors). So I bet your 2014 Klass Kote is still good. Test a small mix to see if it hardens.
            Here's a tip on brushing the Klass Kote. It says to let it activate in the cup for 30 minutes before using. I found it would not flow as well towards the end because brushing takes longer. I've been getting great results waiting 20 minutes, then I start using it. It flows better and hardens the same.
            I'm using these 1" wide & 1/2" wide bristle brushes from my hardware store. They are around a dollar each. They work great, then I toss them...
            • sammyha
              • Jul 2018
              • 1038
              #276
              I did get this turquoise pinstripe on today. The color scheme is starting to come together...
                • 9438
                #277
                Very nice, thanks again!
                • sammyha
                  • Jul 2018
                  • 1038
                  #278
                  I said in post #273 I would let the paint cure before handling it to finish up.
                  But with careful handling(the epoxy paint will get marked with fingerprints unless you wait 24 hours), I did get the turquoise pinstripe on the tub.
                  Then I realized I had lettering to do on the sponsons, which are cured already...
                  • sammyha
                    • Jul 2018
                    • 1038
                    #279
                    And it gets even more tedious. The smaller white "Boatworks" lettering will be done with white paint.
                    I got the tape cut out for one side.
                    One more to go... [emoji41]
                    • sammyha
                      • Jul 2018
                      • 1038
                      #280
                      There's a nice quality look to painted stripes and lettering. Something you don't get with stickers.
                      Here's some pictures that tell the story about how I did it.
                      I cut this stack out with a #11 exacto knife...
                      • sammyha
                        • Jul 2018
                        • 1038
                        #281
                        Here's what's the stack consists of.
                        The clear is transfer paper from Amazon...
                        12" X 10ft Clear Transfer Paper... https://www.amazon.com/dp/B06XY8CLCG?ref=yo_pop_ma_swf
                        The small pieces are from inside the letters...
                        • sammyha
                          • Jul 2018
                          • 1038
                          #282
                          The transfer paper goes sticky side to sticky side of the low stick blue tape. I cut thru my computer printed letters and the blue tape and transfer paper.
                          The stack is taped to a sheet of paper folded in half. Makes for a nice clean cut...
                          • sammyha
                            • Jul 2018
                            • 1038
                            #283
                            Separating the transfer paper from the inside pieces...
                            • sammyha
                              • Jul 2018
                              • 1038
                              #284
                              And place inside the letters...
                              EDIT: Grrr, that annoying upside down thing!
                              • sammyha
                                • Jul 2018
                                • 1038
                                #285
                                I used a cut down 1" sponge brush and dabbed the paint on these small letters...
