Motor Mount Suggestion
  • klloyd67
    • Jun 2017
    • 55
    I'm new to the FE world, as I'm getting closer to completing my 1/10 scale U-3 Hydroplane. I have a question about motor mounts. I initially will be running a Tenshock Viper 2260 10T 1600kv motor, I realize that it doesn't meet NAMBA guidelines, however will be running it for fun before I decide on whether or not I will race it. The motor is an odd 38mm diameter. My question is whether a 36/40mm motor mount will work. It is 60mm long and has 25mm spacing between mounting holes. Any motor mount suggestions would be great.
    Thanks,
    Kevin
  • ETOWNE
    • Mar 2008
    • 299
    Maybe ? 25mm bolt pattern
    https://www.offshoreelectrics.com/pr...prod=ose-80902
    Vortex 22 hydro ammo 36-50
    Vortex Cyber Storm 33 P spec Mono AC 36-56
    PT SS-45 Q-hydro Neu 1527/1Y
    • klloyd67
      • Jun 2017
      • 55
      Thanks, yes 25mm bolt pattern, thought about that one, wasn't sure whether or not it was strong enough.
      • ETOWNE
        • Mar 2008
        • 299
        I think 25 mm bolt pattern is common. You could get one of the blue ones ose sells or get a 40 mm and use something to shim it with. 1mm shim stock maybe. I run a mount similar in my 22 hydro on 4s and at first a fiego motor. Mount was fine, hull didn’t like the power. Just put a piece of c/f over it or fiberglass.
        • Prodrvr
          • Jul 2015
          • 701
          I've had 40x82 motors on that mount with more 68 mph flips than I care to mention...didn't skip a beat! It's damn strong.
          • klloyd67
            • Jun 2017
            • 55
            Thanks
            Sent from my VS985 4G using Tapatalk
